SR20DET parts guide
Troubleshooting, DIY's, How-To's and articles about all Nissan vehicles. Non-vehicle specific "General" How-To and tech information is also here.
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
Exhaust Manifold Gasket '91 Sentra SE-R w/SR20DE
T25 Turbo gaskets '90-'95 300ZX TT T25 gaskets (note turbo to O2 housing gasket dose not fit on S13 T25)
O2 sensor '87 300ZX Turbo
Ignitor chip '95 Q45
Fuel Injectors '95 300ZX TT (purple plugs)
Fuel Injector Seals '95 300ZXTT kit
MAF '89-'90 SOHC 240SX
transmission rear main seal '93 240sx
Slave cylinder '93 240sx
T.O. bearing '93 240sx
Pilot bearing '93 240sx
Clutch 89 Nissan Maxima 240mm 9-7/16" spline 24x1
Belts (PS, AC, alt) Gates K050370 Alt. K040345 PS & AC
Spark Plugs NGK BKR7ES11 or BKR6 (hoter plug)
Coil Packs '90-'95 300ZX or '95 newer Maxima
S14 SR Oil Filter '95 Sentra SE-R
S13 SR Oil Filter '91 Sentra SE-R
Fuel filter '90 300zx TT
Front and Rear main seal '91 SE-R
TPS '95 KA TPS will work with some soldering
Temp sensor S13 or S14 (depending on chassis not motor) KA24DE temp sensor
Thermostat '91 Sentra SE-R
Radiator cap '90 300zx TT (slightly more pressure for better cooling over stock cap)
Knock sensor '95 240sx
Oil pressure sender '95 240sx
The only parts you really need to get from Japan are the starter, alternator, water pump, and headgasket. Most everything else can be found locally or adapted to fit. Please add to this list if you can find or think of anything else. Also corrections are appreciated.
Paul
Movingviolation240
Let me know if anybody can think of any other applications, I'm going to keep adding to this list with those so it dosn't get too long and loose it's usefullness
Paul
Movingviolation240
I got this off my old standby website Nissansilvia.com out of australia, might be of some use to you guys since Nissan seems to use a lot of the same part numbers internationally.
Part type Nissan Australia part number Other source or comments Oil filter 15208-H8911 Ryco Z145A (CA18 all?) Door bump rubbers 01658-J7000 (Skyline R31) Exhaust manifold gasket 14036-D4200 (EXA 1.8, S13 CA18) Four separate pieces Intake manifold gasket 14035-D5710 (CA18 all) Injector rail to cylinder head Intake manifold gasket 14035-D5711 (CA18 all) Injector rail to intake runner Intake manifold gasket 14035-53J10 (SR20 all) Turbo inlet flange gasket 14415-75F10 (200SX) or 14415-17M00 (S13 all) The Aust 200SX one fits. Turbo outlet flange gasket 14445-26E00 (S13 all) Engine front oil seal 13042-42L00 (CA18 all) Engine rear oil seal 12279-18V00 (CA18 all) Oil pan seal front 11121-01F10 (CA18 all) Oil pan seal rear 11121-01F15 (CA18 all) Head gasket 11044-51E00 (CA18 all) Head gasket 11044-50F00 (SR20) until 9/92 Head gasket 11044-50F01 (SR20) from 9/92 till 7/93 Head gasket 11044-50F10 (SR20) from7/93 onwards Engine gasket kit 10101-51E25 (CA18D) Engine rebuild gasket kits Engine gasket kit 10101-56E25 (CA18DET) Engine gasket kit 10101-50E25 (SR20DET) Engine gasket kit 10101-51E26 (SR20D) Valve grind gasket kit 11042-51E25 (CA18 all) Valve grind gasket kit 11042-50F25 (SR20 all) Fan belt 11720-V7301 (CA18 all) L = 855mm Fan belt 11720-52F00 (SR20 all) Compressor belt 11920-V7301 (CA18 all) also suits power steering pump Compressor belt 11920-30R10 (SR20 all) also suits power steering pump Water pump 21010-V5528 (CA18) until 8/90 Water pump 21010-V5529 (CA18) from 8/90 Water pump 21010-52F00 (SR20 all) Thermostat 21200-V0201 (CA18 all) 82.0 C Thermostat 21200-V0206 (CA18 all) 88.0 C Thermostat 21200-53J00 (SR20 all) Radiator cap 21430-01F01 Radiator hose - upper 21501-35F10 (CA18 all) Radiator hose - lower 21503-35F00 (CA18 all) Radiator hose - upper 21501-52F00 (SR20 all) Radiator hose - lower 21503-52F00 (SR20 all) Bonnet bump rubbers (large) 62840-D0100 (Skyline R31) Engine coolant 10120-89904 Castrol Dash switch back lights Nissan Aust, have similar types $11.00 each **** Smith P8130, with fiddling needed or 12v lamps WT2-12 from WES Components, good fit. 65c each Radius rods (Tension rods) 54468-35F20 (S13 all) includes bush Genuine Nissan imports (JSVA), Remanufactured with Urethane (Cars of Saigon ). Wheel nut 62840-21001 (R31 Skyline) Brake pads See service info page. Bendix and others. Headlight globe Who cares Any brand. H4 60/55W 12V or H4 100/55W 12V the second one has 100Watt high beam. Rear Dampers ( shockers ) See Nissan Dealer or Nismo KONI. Part no. 80-401-081 sports kyb. Approx $315 a pair. Fuel filter 16400-F5100 (CA18 and SR20) RYCO Z202 Air Filter 16546-V0100 (same as R31 Skyline) K&N high flow reusable type P/N 33-2031-1 Spark plugs 22401-58S16 (PFR6A11, CA18) Non resistor type NGK BCP6ES11 (11 = gap of 1.1mm) Spark plugs 22401-53J16 (PRF6B, SR20DET) Crank angle sensor 23731-85M10 (CA18 all) Crank angle sensor 23731-50F01 (SR20 all) Coolant temp sensor 25080-89903 (S13 all) Oil pressure sender 25240-89920 (S13 all)
prjct240sx
do you know of a cross reference part that can replace the crank angle sensor cover??? mines is broken and i have no idea of where to locate a new cover?? thanks
i have searched and checked but found no info on this part, thanks...
TeeJay
Car: cars, pie, cars and pie
how about the timing chain?
hurddawg
Car: anything with 4 wheels.
sr20de's timing chain will work
180fan
Car: 89 fastback
ooo so for the timing chain kit for a sr20det, I can get away with using a SR20DE's timing chain kit? I assume from the 91 SE-R?
hurddawg
yup, but it'll be cheaper if you get one for a 91 G20 at infinitipartusa.com
not 100% sure about the guides but I know the chain works. Let put it at high probablity that the guides work. I vaguely remember someone saying it worked on their rwd SR.
180fan
Car: 89 fastback
Alrighty so I can use the following 91 SE-R parts in my timing chain job?
13028-00008 Timing Chain 13070-00008 Timing Chain Tensioner 13079-00001 Timing Chain Tensioner Gasket 13085-00004 Timing Chain Guide - Tension Side 13075-00004 Timing Chain Guide Tension Side Bolt 13091-00005 Timing Chain Guide - Slack Side 13094-00003 Timing Chain Guide Slack Side Bolt 13510-00002 Front Crankshaft Oil Seal 15066-00003 Front Cover O-Ring
and those badboys will work no prob in the DET eh? I got those parts and part #'s off of courtesyparts.
thanks
hurddawg
what is the front cover oil ring? my s13 blacktop didn't have that.
the crank main seal will work definately. as well as the chain. The bolts will work as well.
I dunno about the tensioner and guides, I've seen both rwd and fwd tensioner and guides they look similar but I never tried them or compared side to side (I have a g20 in addition to my 240). If I was planning on changing the guides I would buy the fwd guides and tensioner. But just beware that it may not fit.
If you have a S13 redtop the tensioner will look different from a new part btw, Nissan redesigned the tensioners on the SR around 94 because they tended to fail. The new one should be beefier looking. FYI.
do recommend using infinitipartsusa.com (p.s. you can order Nissan parts through there too) though, prices are almost always cheaper and shipping is waay faster than Courtesy.
starfireS14
What are the US Nissan Part numbers for the Drive Belts I have s13 blacktop? Or who sells Gates Belts?
hurddawg
take your gates part number to any parts store they will get you the proper belt.
I did this at my local place and they gave me Dayco belts and they worked fine. The guy told me that part numbers for belts are standardized. So they can cross-reference them easily.
K050370 AltK040345 P/S
K 05 0370....05 indicates # of ribs, 0370 indicates length of the belt. K signifies its made my Gates.
jberg240
Car: cars
you forgot something for the sr thats really important and was one of hte first things that I swapped on mine was the RADIATOR! I found koyo offered the cheapiest one.
Phax
Car: Control dynamics
The crankshaft main bearings and thrust washers from a 92 SR20DE will fit a 92 SR20DET.
Tastyratz
Car: 240sx
what about oil pump?
skyliner
Hi,
Will the SR20DE (Nx 2000) fuel rail work for the SR20DET (180sx), i know that the FPR is on the other side and i would only be able to use 3 of the 4 brackets, but i'm not sure how important it would be.
Thanks
skyliner
anyone know???
cnichols
Car: 96 Nissan 240SX
99 Infiniti Q45
93 Ford Fastiva
Also...for those running standalones that use GM style connectors (Electromotive, etc.), a 1998 Corvette coolant temp sensor threads right into the stock sensor location and of course uses a GM style connector.
180fan
Car: 89 fastback
The o ring sits behind the front cover bascially under the water pump. The timing chain tension side guide for USDM spec is better than the JDM one since the USDM one is metal while the JDM is all plastic.
The intake collector gasket is different from the SR20DE. So is the turbo inlet gasket from that of the VG30DETT. You'll have to take a file to the gasket's bolt holes to make it fit.
I'll list more erratta as I encounter them with my build up.
Return to “Nissan Articles”
