SR20DET Parts Guide
gtune4
Car: toonah
that is awesome, thank you!
only place i could find a new one had it for 600$!
AmoebAssassin
Car: 1991 Base fastback 5spd, black
Some things I found out along the way:
SR20DET Crank bolts are M10x1.0 and will interchange with dodge omni GLHS crankshaft bolts. The Dodge bolts are 1 thread shorter and slightly heavier, so make sure to replace the opposite bolt to the one you're missing or replacing with a dodge bolt, so as not to throw off the rotating assembly.
Transmission bolts are M12x1.0 and any autozone will have these bolts in grade 12, in incrementing length by 10mm in the back of the store, you need to ask for the length.
NCturbo75
Car: 2006 INFINITI M35...
it's a little off the subject....but those two s13 valve covers are different shades of red.
tonis56
Car: 04 Titan Crewcab
Is there a specific part number for the item circled in red. The small plastic piece that sits above the lower seal.
thanks in advance
tony-
generic_drifter_S13
Car: nissan silvia S13
hey bro whats up??? i got a 91 silvia with a red top in it. i think its a 93 motor. my water pump went out. now when i pulled if off it didnt have a gasket. if i can find a gasket or make one. do you think it will work. also my starter went out. would it be better for me to rebuild it or to just find a new one. its and S14 transmission but the bell housing im almost exact is an S13. im new into the silvia's so im tryin to learn everything about them.. ive had mine for about 2 months now and i fell in love with the thing... but if you can help me out that would be awesome...thanks bro
C - ROD
Car: SR20DET pignose hatch
does the FWD SR20DE oil pump & front cover assembly work on the rear wheel drive SR20DET?
& what about the Thermostat?
C - ROD
waterpump?
C - ROD
thanks, & 1 last thing, the valve stem seals & valve guides
C - ROD
thanks - i can get them cheaper through my work
C - ROD
what about the intake & exhaust valves & valve springs?
C - ROD
SpeedRacer1 wrote:Valve springs are same as an FWD SR20DE.
but what about the valves
swiff
Car: 240 sx
whatup u guyz. my names swiff i just joined, i just whanted 2 hear other peoplez oppinion, id appreciate it. ive bassicly desided on the sr20det swap for my 1990 s13 240. butt i still in some ways debate my original idea of swapping the rb26dett. the only reasons i changed my mind wass because a mixture of the price and difficulty. i would appreciate hearing others oppinions.p.s. as a rappa and drifter it kind of became enevadable that i made music for other drifters and rasers. the music i make for us is outside of my regular music career. i dnt whant ta make money from these songs i just make them so people that do what i do can vibe with it so if you would like to hear some of my songs just lett me know ill send u some.
C - ROD
ok this is truley my last question - how do i decide what size bearings i need to get, should i just get regular size if im not machining my crank & if i machine it a litt just get like .0010 - .0020 over sized?thanks for all the help speed Racer, i just dont want to get the wrong parts for the rebuild on my sr
Shaefer Thomas
Car: 1992 240sx
Thank you SOOOOO much to ILikeMy240sx for these numbers. Dont break off the camshaft cap bolts in the head, but if you do... here are some numbers
Camshaft Cap Bolts-Longest (bolts that go into the oil squirters): Unknown #Middle Size (approx 2.4 inches in length, M6 thread): 13058 53J00Shortest: 13058 56E00
We dont have the numbers for the longest bolts, but for the middle and smallest ones we finally have the numbers!!!
Got the bolts in today, part numbers are GOOD!!!! Woohoo!!
Modified by Shaefer Thomas at 9:34 AM 2/20/2007
TonKpilS14
Car: S14 Silvia
I REALLY NEED a S14 sr20 Clutch fan. if somone has one please let me know. i can't find one anywhere.
nightrunner1
Car: s13 and evo
can anyone help me i need a part number for the cam bolts that have the oil squirters attached to them
Lynex
Car: 96 S14 (Dead - T-boned)
Theres no way I can swap over the alternator from a SR20DE out of a Sentra over to a redtop S13 SR20DET?
turbobrick
Car: 1990 nissan 240sx
Hey, what is the part number for a coolent temp sensor for the ecu, for a s14 sr?
Its not the same as the ka, is it?
TonKpilS14
Car: S14 Silvia
hey if anyone wants a S14 sr20det MAF (mass air flow sensor) hit me up. [email protected]
turbobrick
SpeedRacer1 wrote:
For a 1993-early 1996 S14 SR20DET use 22630-51E00 found on many US Nissans.For a mid 1996-1998 S14 SR20DET use 22630-44B20 found on many other US Nissans.
How do I find out what year my engine is?
turbobrick
I went to the dealership and they gave my 22630-51E02, which is the same one from the ka, and said it was the same thing.
Slipstream
Car: '94 Sonoma, '90 300zx n/a
Is there a way to cross reference the actual numbers on your block or head to find out what year and version of engine you have?
Slipstream
How would I break those down? I know the head is stamped 52F. I haven't really remembered the other stampings.
boostedkouki
Car: 1997 Nissan 240sx
Is there a usdm equivilent pcv valve for the s14 sr20det?
sr20detRcr1
Car: 92 Nissan 240SX
anyone have the parts # on the s13 sr powersteering belt and the bolts that attach it to the engine, or what other alternatives there are for the belt
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
hurddawg wrote:take your gates part number to any parts store they will get you the proper belt.
I did this at my local place and they gave me Dayco belts and they worked fine. The guy told me that part numbers for belts are standardized. So they can cross-reference them easily.
K050370 AltK040345 P/S
K 05 0370....05 indicates # of ribs, 0370 indicates length of the belt. K signifies its made my Gates.
This should answer your question rb26. It's on the first page of this thread btw.
574-240sx
Car: Nissans, Toyotas, Subaru
Looking at the bottom end part number on the thrust washer is that the same as the thrust bearing?
streetspirit7
Car: '97 240sx
will the 87 300zx O2 sensor work for the S14 SR or just the S13?
guilty_coupe13
Car: a S13 coupe
What will work for a throw out bearing for S14 SR20DET? I've herd 93' 240sx and 93' Sentra SE-R does anybody know for sure what will work?thanks
turbobrick
What about spark plug wires for the s14 sr20de? Will sentra se-r wires work?Also, I'm assuming the sentra spark plugs will work because they're both the n/a sr.
Modified by turbobrick at 8:05 PM 4/4/2007
