SR20DET Parts Guide
grosspolluter
Car: Nissan Skyline
Nice post.....I bet that took alot of work to put together.
nismonate
Car: drums, women, and cars, ****, who needs anything else?
i need a powersteering line for the driver's side. anyone have the part # for that at autozone?
jmancuso
Car: Nissan 240SX 1992
Hey all these part#'s are great........just one question are they American numbers or Japanese? I called the local Nissan dealer looking for a water pump and gave them this number (Water pump Jan 1991 - Dec 1998 21010-52F01) and they say it is a invalid number. Can you give any guidance on locating a water pump?
nothingFancy
Car: r34
bump for the SR alternators.
my sr alternator took a **** , it was a 80 amp alt. to replace your altanators you buy a ka24de 80 amp alternator and with no modifications it bolts right in, for the pully part you need to put a 1\4" thick washer then put the pulley on then the nut to use the 5 rib pulley
wildacexxx
Car: 2002 Q45 nav sport
anybody know the part number for the 2 prong coolant temp sensor (the one that sends to ecu not the gauge)?
wildacexxx
ok thanx. i bought the one thats listed on the first page but its the one that sends to gauge and i need the one that sends to ecu. thanx again.
elvis240sx
What about a part # for the crank angle sensor gasket? i know its just an o-ring but it would be nice to have the proper one. thanks!
elvis240sx
is that a japanese part number? i cant seem to get it to work
gtune4
Car: toonah
so there is no other option for a starter than to get an s-13,14,15 motor from somewhere?
what about what the guy said about switching the internals from the ka sohc into the bracket of the sr starter?
tiger
If this hasn't already been said.....
91-99 (FWD) Rod Bearings, Main bearings and Piston rings from the SR20DE do cross over and you can use them in the SR20DET.
180fan
Car: 89 fastback
efrain240sx wrote:can you gust plug it in into the stock harness
Yes the suzuki sidekick's ignitor chip will plug right into the sr harness.
tonis56
Car: 04 Titan Crewcab
SpeedRacer1 wrote:Piston oil jet assembly:Redtop - 11560-79E00Blacktop/late redtop - 11560-1E000
I checked courtesy nissan for this number and nothing came up. However when I type in "oil jet" the part number 11047-W0500 and 11047-21000 came up.
UltraRed2$0sx
Car: 97 S14
Whats up guys....I was wonderiggn if anyone can help me find out teh part number for:
Manual transmission Bellhousing BOLTS.. Preety much transmission bolts. I have heard that the Sentra SE-R work but i rather be sure before i order them.
Also....These parts:
Upper waterneck Jan 1991 - Aug 1996 11060-52F00, 11060-52F01Upper waterneck Aug 1996 - Dec 1998 11060-65F00, 11060-65F01
which one is the part number for the cooling passage in the exhaust side...The one that goes underneath the Distributor/CAS.
Im working with an NA RWD SR20 if tha makes a diff.thanx
Paul
tonis56
SpeedRacer1 wrote:The part numbers that I listed were JDM only numbers, there is NO US crossover for that particular part. The part numbers I listed were for the oil jet that sprays the underside of the piston. The numbers you just listed are just the little metal tubes that go between the block and the head to traffic oil.
Is there a place that might sell the JDM ones?
myees13
Car: 90 s13 coupe
gtune4 wrote:so there is no other option for a starter than to get an s-13,14,15 motor from somewhere?
I just did this yesterday.
Donor starter from S13 KA24DE
-Remove SR starter-Take them both apart (2 long bolts on motor/2 short bolts on soleniod)-Re-use SR bottom part/bracket-Install the KA starter motor and soleniod onto SR bracket-Re-install hybrid starter
I had to get creative with the small clip that goes to the soleniod. It works great!
Email me if you have any questions about it.MyeeS13 @ hotmail. com
Modified by myees13 at 9:22 AM 6/15/2007
180fan
Car: 89 fastback
For those of us in need:
Nismo exhaust hangers: 20651-RS230
tiger
Hey, the japanese part numbers for the exhaust valve seals cross over to the VG30 and the intake valve seals cross over to the SR20 DE.... i'm about to rebuild my SR20DET head and I need to know if I need to get intake seals from the sr20de and exhaust seals from the VG... is this right, or should I get all seals from the SR20DE ????
AND...
that baffle plate... does anyone know the PN? Is it called "upper baffle plate"or Crankcase baffle plate??? help. thank you
180fan
Car: 89 fastback
I left the US part numbers on the first page for the valve stem seals and the engines they come from
tiger
Sorry 180 fan, I guess I didn't see it. Thank you speed racer for the PN. I misplaced that baffle plate and I just couldn't be ghetto and rebuild it without it, It's there for a reason! Gracias!
s14brent
Car: 07frontier 4x4 6spd!
sorry but iirc the sr20det uses Z32 tt rear main seal. part # ends in AD205. this is for the first post that says 93 KA one fits.
streetspirit7
Car: '97 240sx
I didnt' see it anywhere in this fourm, but I'm looking for a crossover part for the O2 housing gasket (between the turbo and O2 housing) for an s14 sr. Anyone one know if there is one?
analogassassins
Car: 1990 nissan 240sx
can anyone here please let me know if the 300zx TT fuel injectors will fit into my blacktop sr20det? got a problem with mine, stuck or something. need quick easy fix and dont want to spend $300 on 550cc upgrades just yet, unless someone knows where i can get a cheap upgrade for the 370cc injectors in my SR. please help. thanks.
sincerely
billy banalog presidentmyspace drift team
S13FASTBACKSR
Car: '92 Fastback SR powered
been almost a month since you asked this question analogassassins but yes you can use a '95 300zx TT fuel injector..of course look the picture of it up on advance auto parts website or autozones website and make sure it looks the same.
Drake
I was curious about that too, i've looked at courtesy and even tried googling the part number for those jet's. Does any one have any idea where I can get my hands on them(oil jets)?
corey240
Car: 1993 Nissan 240SX Base Drift Machine
just to clear any questions up the sr20de crankshaft is interchangable with the det and so are the bearings, would the crank pulley work too?
wei240
what about head studs - oem part number(s), i know the arp parts are listed, but what about oem ones?
thanks
tiger
there are no such thing as oem sr20det "studs" ... there are head bolts. I would think they would be the same as the Sr20de's... call up nissan and find the pn and hopefully that dealer will have a jap parts catalog and they can cross reference the pn's...if they are the same then you have a match
wei240
Anyone know the part numbers to:
http://phase2motorsports.store....html
I'm inquiring about s15 T28, but in order to have it fit in the s13 easier, there are a couple things that'll make life easier, according to phase 2:
- S14/S15 Turbo Oil Return Hose- S14/S15 SR20 Turbo Oil Return Tube- S14/S15 Turbo Outlet Pipepad- S14/S15 Turbo Inlet Pipe
They all look to be factory OEM parts...
Thanks
rob-s
Car: 91 240
Ok, heres the questions. Ive been looking for info on getting a TPS. and cant seem to find a definate answer.
What year make and model options would have a tps for a sr20det redtopPlug and Play would be best but if some wiring is needed please specify what color goes where
My goal is to save a few bucks by just buying it from the parts store.Thanks in advance.
-RobIndependent AmsOil Dealerhttp://www.robsoil.com
koukicody
Car: 93 Mazda Miata
any US crossover for the radiator itself, or any other nissan radiators that are the same?
