SR20DET Parts Guide
180fan
Car: 89 fastback
Update: The ARP main studs for the most part will clear the upper oil pan, but the last two on the drivers side (if you're looking at the motor while on a stand with cylinders pointing down) will not clear the upper oil pan. You can trim these down.
mynameisjonas
are there any crossover numbers for the s13 redtop coilpack part number 22448 50S00 ?
mynameisjonas
does anyone know where i can get the fuel injector orings shown in the picture? what i need is the one with the red rtv sealent on it
RobDET
Car: Cars
Just did some playing with oil drain plugs. For the redtop SR20 with a stock oil pan the 93 Sentra SE-R plug DOES NOT WORK. (it didn't for me at least)
The one from the 93 240sx (Ka24de) works great. It's the same part as the NA 300zx from the same year. (Maybe the turbo 300 too but i didn't look at the part number)
Also i just did a head rebuild and the exhaust valve guids and valve seals are not the same as the SE-R either. I had to get mine from JWT. I'm sure that's on the list somewhere though.
Hijacker
Car: '92 240sx Convertible
'94 F-150
all of the trans plugs for a KA transmission should swap over. In fact, I just recently put a 95 S14 reverse sensor into a redtop trans and it worked.
As far as timing chain goes. Everything will cross over that is in the FWD SR chain kit. The only part that will not work is the exhaust cam. The FWD SR drives it's distro off the rear of the exhaust cam whereas the RWD SR drives it off of the cam gear. I had to reuse my exhaust cam gear when I did my chain a few weeks ago.
deathBooster
Car: 240sx under construction
Need to know which is the correct oil dipstick for the SR20det??? my motor come with a wrong one.. I was pooring 6-7qt in my motor help...
RobDET
Car: Cars
Dipstick...
http://srownersclub.com/Mercha...EMENG
Don't have a PN sorry
noodl35
anyone know the part number for the sr20det crank sprocket and the keyway that goes in it?
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
SpeedRacer1 wrote:180SX Jan 91-Aug 96 AY040-NS929180SX Aug 96-end AY040-NS041
I hear the Altima front brakes are similar or the same size as the larger JDM S13 brakes. But the part numbers arent the same.
They are actually the same pads used on R32 GTS-T's not that that helps at all.
Really? R32 GTS-T's use 300zx calipers, or at least the set I have look identicle to Z32 calipers.
civicsi2
how about PCV valve?
stiergott
Car: 240
you can take the motor(the big gold bit) and bolt it to the sr braket. you have take the starters apart and use the base of the sr starter. i've only done this with the a ka24e starter motor, i havent tried it with a DOHC starter.
180fan
Car: 89 fastback
Ignitor chip33370-77E20 from a Suzuki sidekick awd sport.
180fan
Car: 89 fastback
Oil pickup gasket - 15053-1E400S13 spark plug gasket (for valve cover) - 13270-53J13 (this is the center one)s13 coil pack gasket (for valve cover) - 13271-52F00Oil sender block o-rings - 15066-5E510 (you need 2 of these)s13 valve cover gasket - 13270-52F00turbo oil line o-rings - 15193-03E00
Modified by 180fan at 11:05 AM 5/13/2005
180fan
Car: 89 fastback
S14 Throttle pulley - 16134-65F00
9095240SXDUCK
Car: 240SXs
Sorry if I missed it.
But what Valve cover gasket and cam seal does a red top SR20DET use?
CO S13
Car: S14
SpeedRacer1 wrote:Oil strainer: Redtop - 15050-52F01Blacktop/late redtop 15050-65F01
I need one of these but how do I tell if it's a late redtop or an early one?
9095240SXDUCK
Car: 240SXs
SpeedRacer1 wrote:Part number is 13270-52F00. Its available in the US though im not sure which car its on. Should only be about $10.
Use any sealant you want for the cam seal.
that is the wrong part number! it looks like its for a KA
S14owner95
Car: 95 240SX, S14SR, JIC Suspension, Mad Tyte Stickers
The KA24E alternator will work also, it's a different part number than the DE alternator, but I'm running it right now. The DE and the E are both 80 AMPS, while the SR is 90 AMPs, so just be careful with the battery and stuff.. same thing, just drill out the KA24E bracket to make it fit.. it's a 3-Rib as opposed to the SR's 4-rib.. cut a rib off, or get the pulley off, I had no idea how to do it, so i just cut the belt.. so yeah..
efrain240sx
Car: 1992 nissan 240sx HB
180fan wrote:Ignitor chip33370-77E20 from a Suzuki sidekick awd sport.
can you gust plug it in into the stock harness
civicsi2
I'm not sure where i got this part # but its the wrong one for the flywheel bolts. Left bolt is from my sr20 flywheel. p#12315-62J01.
slide240wayz
I need an upper waterneck for an S14 SR20DET. Where can I find one.Thank you.
Mastaflash
Car: cars
im a little confised here, can i take any of these parts numbers listed and have my local nissan dealer order it? even if it is a JDM part?
Neil
Car: shooting laser guns
SpeedRacer1 wrote:Con rod bearing (standard-0) Aug 1996 - Dec 1998 12111-1N500Con rod bearing (standard-1) Aug 1996 - Dec 1998 12111-1N501Con rod bearing (standard-2) Aug 1996 - Dec 1998 12111-1N502Con rod bearing (standard-0) Jan 1991 - Aug 1996 12111-60J00, 12111-1N500Con rod bearing (standard-1) Jan 1991 - Aug 1996 12111-60J01, 12111-1N501Con rod bearing (standard-2) Jan 1991 - Aug 1996 12111-60J02, 12111-1N502Con rod bearing (US 0.12) Aug 1996 - Dec 1998 12117-1N500Con rod bearing (US 0.12) Jan 1991 - Aug 1996 12117-60J00Con rod bearing (US 0.25) Aug 1996 - Dec 1998 12118-1N500Con rod bearing (US 0.25) Jan 1991 - Aug 1996 12118-60J00, 12118-1N500Con rod bearing (US 0.8) Aug 1996 - Dec 1998 12122-1N500Con rod bearing (US 0.8) Jan 1991 - Aug 1996 12122-60J00
so, uh, which part# of these would I want for my blacktop?
180fan
Car: 89 fastback
you know the grades you need?
andrewmp6
hey guys im new to this form but i got 91 hatchback i want to swap in a sr but im gonna rebuild it good before i do im looking for a high flow oil pump i havent found one yet anyone know where to get one or will one off a different nissan work
Neil
Locking washer plate Jan 1991 - Dec 1998 14495-17F00 that's jap, yeah?
Think a 300zx's T25s have these locking washer plates? I dont even want to use lock washers because i dont think theyll help when they heat up, but my lock-tabs are work hardened and weak.
i should probably go to the nissan dealer and pull up an exhaust system parts diagram.
kineticniwa
so i'm having this problem with my o2 sensor, i upgraded it with ssatuochromes turbo elbow. and now my redtop o2 doesn't fit because it's too small. so is the 87 300zx turbo o2 sensor my cure to this problem? just making sure.
574-240sx
Car: Nissans, Toyotas, Subaru
which o2 sensor will work for the S14 SR?
180fan
Car: 89 fastback
Hey Speedracer1, was I right about the US part number for the timing chain oil jet?
13081-53j00
gtune4
Car: toonah
the 300zx front transmission seal will work with sr20det transmission?
