SR20DET Parts Guide
White Comet
Car: fc, s13 and mazda6, Sierra
Hijacker wrote:180SX side glass (right) Jan 1991 - Jan 1995 83300-47F00180SX side glass (right) Jan 1995 - Dec 1998 83300-47F01180SX side glass (right) Sep 1997 - Dec 1998 83300-47F02180SX side glass (left) Jan 1991 - Jan 1995 83301-47F00180SX side glass (left) Jan 1995 - Dec 1998 83301-47F01180SX side glass (left) Sep 1997 - Dec 1998 83301-47F02
this might be a stupid question, but why are there 3 different part numbers for each side? i've only ever seen one style of 180sx glass, its not like they changed designs iirc.
VNG704
That is a timing chain tensioner and it's by your water pump. the spot under your car by the transmission/upper oil pan is missing the plate cover.
I need part numbers for the camshaft caps (FSM calls them camshaft brackets) for a blacktop (chuki, not kouki) S13 SR20DET. thanks.
Hijacker
Car: '92 240sx Convertible
'94 F-150
White Comet wrote:this might be a stupid question, but why are there 3 different part numbers for each side? i've only ever seen one style of 180sx glass, its not like they changed designs iirc.
I just c & p-ed the parts list. I'm sure there were small revisions to the glass that warranted new parts numbers.
cartoonlips7
Car: 90,89,96 240sx
so would it be a big deal if order standard bearing pack main and rod sets for a 91 sentra se-r and rings to do my sr20det red top rebuild. my bearings are all the same on my mains and rods. know u have to cross numbers but looks like this motor had minimal wear with all the same bearings. i never saw the motor run.. but everything looks good. also. on the bottom of the block (exhaust side.) there is a connector that threads into the block near the rear. by connector i'm talking looks like a 1/2 inch tube goes to in.. myn somehow dissapeared.. i'd post a pic but yeah its gone and i don't know much else to explain it.. basically looked like a treaded end with a pipe coming out that a tube connects to. not even sure where to get one.... please help a noob =)
KA-TASROPHE
looking for the part number to the crank sprocket assembly
1.crank sprocket 2.the metal thing that in font of it 3.locks
all4sho
Car: LOTS of Nissan's
sprocket 13021-53J00spacer 15041-30R01key 00926-51600
i don't know what lock you are talking about
KA-TASROPHE wrote:looking for the part number to the crank sprocket assembly
cartoonlips7
Car: 90,89,96 240sx
i have 4 coil packs for red top sr20det will sell for 40 a piece or 120 for all of them and the wire harness for them.. they are spare off my old engine
cartoonlips7
Car: 90,89,96 240sx
so it seems i missed placed my oil dipstick tube..does anyone know if i can use one from a sentra se-r or a 240? redtopsr20det
chicos240
Car: 1995 240 SX
It took me forever to find this part # till i got my FAST workingbasically a coolant plugPlug Blind 11051-53J00Weirdest size/pitch ever
White Comet
cartoonlips7 wrote:so it seems i missed placed my oil dipstick tube..does anyone know if i can use one from a sentra se-r or a 240? redtopsr20det
i have one that will work for you. brand new in the bag from nissan. let me know if you're interested
duffman1278
Car: 89 240sx Hatch, the wildcats!
I hear the Sentra ones pop off but if anything I got mine from here. It's the SR one.
http://www.mynismo.com/products/?id=4337&rsku=0
White Comet
^ i looked into when i needed the dipstick and the sentra one is a diff part number so idk
saywuh
Car: 95 Nissan S14.5 240sx
is BKR7ES11 is colder or hotter ? cause it said or hotter plugs
awhite69
Car: 240sx SR20
16432-40P00 off a VG30DETT should work for the oil feed banjo bolt to the block.
Jah1mon
Car: s13 coupe
Does anyone know the p/n for the clutch cover bolts on a s13 Sr20det?
edmontontom22
Car: 1995 240sx sr20
This might have already been covered.I need to know the part on the throttle body cable that connects to the throttle body bracket where you tighten the two screws to hold it tight to the bracket. sorry if that doesnt make sense
Thanks
Arabrockermang
Car: 93 Nissan 240SX Convertible
Does anyone know what distributor cap would work for a s13 sr20de???
Arabrockermang
22162 52F10
Thats the distributor cap for a sr20de s13 does anyone know what that would cross reference to so I could get parts at autozone and not the dealer.
Its not a keeper and I'm already not going to make any money on selling it.
Arabrockermang
S13 sr20de
Ok if anyone else runs into this the solution is simple take the plug wires outta a sr20 sentra and the cap and rotor out of a ka24de in my case I just got it out of a 1993. Flip the cap around backwards and copy the firing order off of the original cap + keep the original for later.
oddly a 1997 Mazda 626 was almost the same I was tempted to try using the whole distributor. The output shaft was just slightly longer on the Nissan which is why the caps are different. But I guess they are all Mitsubishi distributors anyways.
Stripes
Car: hatch, coupe
Does anyone know if a se-r sr20 crank pulley will work with an s14 sr20?? Need one asap baaddd.
Huncity240
Does anyone know the part number for the airfilter for a 1991 180sx with sr20det? Or a car that takes the same one.
CRyan
Car: 1997 Nissan 240SX
PN for oil pan. . . I'm almost sure they were the same through S13-15. . .
Mines leaking
all4sho
upper oil pan 11110-52F01lower oil pan 11110-52F10
My_SER
Waterpump Jan 1991 - Dec 1998 21010-52F01is this for a DE or VE?
all4sho
that water pump is sr20det
My_SER
trying to find a water pump for my VE but no one here in phoenix has one. I really need to get one so I can have it replaced.
RFcool
Car: 01 Ducati 748, 1989 SR hatch....yeah baby!!!
Need a reference for...SR20DET...Thermostat water inlet pice that connects to the thermostat housing. Its the piece that comes from the radiator to the hose and at the end of the house connects to the houseing where thermostat is. Would a SE-R one work?
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
Dude, I'm trying to picture what you're talking about, but my brain is fried from this AZ heat. Got a pic?
PyR0NiAk
240sxHitman
Car: Boosted '91 240sx
What car could I get a coil pack to use with my Redtop? and will it look the same? I saw on the 1st page it says 90-95 300zx or 95 and newer Maxima. Is the 300zx NA or Turbo??
