SR20DET Parts Guide
Hijacker
Car: '92 240sx Convertible
'94 F-150
I seem to refer to page 2 of this thread a lot for parts numbers. p/n is 13270-52F00. It is a RWD specific part and there is no US equivilant. The best pricing I've found is from Courtesy Parts.
White Comet
Car: fc, s13 and mazda6, Sierra
i searched through most of this thread for a part and i think my problem is, i'm not sure what the part would be called. maybe a water neck or something? i need the metal piece the upper rad hose goes into that goes under the cas. if it's already posted and i'm too dumb to figure out the correct name, i apologize. it just want to be sure
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Yeah, it's called a water outlet neck, I couldn't find a part number but here's one http://cgi.ebay.com/ebaymotors...37385 this one's for a S14 though.
White Comet
yeah i did some checking then and found the s14 outlet. but i cant find the s13 neck anywhere. any ideas on where to find it?
positron1
Man you're right, everybody only seems to be selling the S14 neck now. They say it's an upgrade but what gives?
White Comet
really? will it even work on the s13 sr? i never really looked into it
positron1
Yeah, it's the same fit but it just has a port that is used for the water inlet turbo line whereas the S13 water inlet line wraps around the back of the block and connects. I thought about getting one of these because I thought you could use that port for a water sensor instead since I already have the water inlet line routed in it's original spot.
Hijacker
'94 F-150
I don't think you can get the S13 neck anymore because Nissan discontinued it. As far as the S14 being an upgrade, I'd call shenanigans as it does the same job as an S13, you just have to block the coolant port.
positron1
Question, could that coolant port be used for a water temp gauge? If so, then I'm gonna get a S14 neck.
White Comet
^ thats what i heard, but i havent seen it confirmed
Hijacker
'94 F-150
If you get the right thread/pitch probe or a bung to mount a probe, I don't see why not.
jr.
Car: nissans x 7
Hijacker wrote:JDM part numberCam Angle Sensor: 23731 - 50F02
Not sure if there's a US equivilant for it. The P/N for the CAS is on the cap, so this is for those of us who never received a CAS cap
are these the same as the se-r & g20 fwd engines have?
Hijacker
'94 F-150
No. SE-Rs and G20s use distributors. As far as I know, there is no known US equivalent
jr.
Car: nissans x 7
how about the valve cover gasket and oil pan gaskets. also front and rear seals. I saw part numbers but are they the same as the fwd sr20.thanks!
Hijacker
'94 F-150
There are dealers (Courtesy, West Covina) that order off the JDM catalogue and keep RWD valve cover gaskets in stock.
Zilvia33
Car: 91 240sx Hatch SH
okay i know a i can use a KA TPS, which takes some soldering... no biggie
but what about USDM SRDE TPS.... OR vg30 tps.... will either of those work.....
does anyone know.....
also about the fuel filter.. i know it say 90 Twin Turbo... but are all VG30DETT fuel filters the same or are the older ones smaller?
Hijacker
'94 F-150
I don't think the US SR TPS will work. Don't know about the VG30, but I'm going to venture and say probably not.
Using the KA TPS doesn't require soldering. It should be plug and play since the SR and KA use identical harness plugs. You will need to swap the throttle bodies because the two use different ways to turn the sensor with the throttle.
x240xdrifter
Car: 1991 Nissan 240sx
can fwd sr20de valve seals work on a rwd sr20det?
moyea
Car: Paddle Shifted 92 240SX SR20DET, 02 Frontier S/C, 90 240sx ITA
Anybody know what these washers/gaskets for the fuel rail are called? Part number? Where to get?
onecrazyfoo4u
Car: 03 Type S
Those damn things get lost so easily, I just used 3 regular steel washers under them....same exact thing. Plus those are like 3-4 bucks a piece if you want to order them.
moyea
What about those big black gaskets that hold the injector into the intake?
positron1
I think the ones on a KA are the same, unfortunately I don't have that engine in back anymore so I can't check it for sure.
duffman1278
Car: 89 240sx Hatch, the wildcats!
If their the ones that go into the counter bore type of thing on the intake manifold, then yes, their the same as the KA. I believe you HAVE to get them from the KA24DE not the single cam. I replaced those on my SR and I remember talking to justin from west co nissan and him telling me it wasn't a JDM only part.
positron1
Justin is cool.
swinter
do you know what size M6 bolt it is?M6x1.0/30?
swinter
Sorry, should've been more specific in my last post...I lost the screws (bolts) for the coil pack cover. One of you posted that they were M6, but I'm not sure of the thread pitch or the length. Can anyone help with that?
positron1
M6-1.0x20mm
swinter
You the man positron. Cheers!
all4sho
Car: LOTS of Nissan's
moyea wrote:What about those big black gaskets that hold the injector into the intake?
those are injector insulators part # 16635-53J00 any dealer can get them for you list price $2.23 each
TRBOMOFO
Car: S13.5 built redtop
SpeedRacer1 wrote:Intake valve stem seal: 13207-DA201 found on many Nissan engines including B13 Sentra SR20DE's. $3.54
Exhaust valve stem seal: 13207-2B500 found on many Nissan engines including S13 and S14 KA24DE's. $3.86
will these work in the SR20DET and what are the Diameters that need to be in there?
