SR20DET Parts Guide
WestCo Justin
Car: S13 coupe
nismo newb wrote:i need the sizes/specs for the banjo bolts for the water and oil line. also if there are any same size parts that can be substituted from another vehicle let me know. also where would i find such parts other than a junkyard or dealership (cant really afford to wait for shipping, or searching all over the place for a possible match)
this is the only thing keeping my motor out of my car right now and i need to pick these up in the morning. thanks.
S13/S14/S15?
nismo newb
Car: 2 liter 90 civic hatch, and soon to be sr swapped s13
s13 blacktop...sorry it was late.
nismo newb
damn this is a slow source of info lol. apparently z32 bolts work sooo yeah....im good now.
WestCo Justin
Car: S13 coupe
nismo newb wrote:damn this is a slow source of info lol. apparently z32 bolts work sooo yeah....im good now.
yes those should be fine if they are the same pitch and size, also you should replace the copper washers since you already have them apart.
otterman
Does anyone know what can be used for the top front cover bolts? The ones that go down through the head and into the front cover to seal it at the top
duffman1278
Car: 89 240sx Hatch, the wildcats!
Can someone verify that the 87 300ZX O2 sensor is the "skinny" O2 sensor for the SR20????
jmancuso
Car: Nissan 240SX 1992
I have a 92 Red Top; Can anyone verify this is a fit,(Coil Packs '90-'95 300ZX or '95 newer Maxima) the part stores cant help me.
WestCo Justin
Car: S13 coupe
If you're looking for the actual JDM skinny 02 sensor, we keep them in stock here.
tiger
Alright, I left my SR20det pump to a friend in Okinawa because I heard that I didn't need it because the KA would swap over... I put the KA P/S pump on and I notice that the pulleys don't line up... what am I to do?
migsk8
Car: 240sx
does the ka24 thermostat cover work for the sr20det ?
zee1121
Car: 1992 nissan silva
does any one know what type of bulbs the dual projectors use on the silvia front end
Hijacker
Car: '92 240sx Convertible
'94 F-150
http://phase2motorsports.store....html
Found Phase 2 Motor carries piston oil squirters for anyone needing them. Not cheap though. $45 a piece.
warallthetime3x
Car: SR Powered 240sx
tiger wrote:Alright, I left my SR20det pump to a friend in Okinawa because I heard that I didn't need it because the KA would swap over... I put the KA P/S pump on and I notice that the pulleys don't line up... what am I to do?
...... Get A SR20 pump.....
Eric-RPS13-
Car: 240sx
ok I have read that the 95 300ZX TT fuel injectors will fit, but are they the same cc? I'm having massive over rich problems right now, to the point that running two steps hotter plugs isn't helping. I'm thinking maybe my 02 is going bad, and the safc is just correcting +/- off that reading so that's the deal, I'm not sure. But also when I got the car tuned I had a leaky injector o ring, so we replaced those, the tuner noticed that my injectors had been over bored, something apparently common in Japan, I've heard of it, but didn't think it was all that common. Anyway what I'm getting at, I want injectors with the stock flow rate so when I trouble shoot I can eliminate variables. I get parts at cost plus 10%, even still I don't want to spend a bunch of money on parts that will do me no good.Here's the other factors, I never had a cat till this year when my favors ran out I guess, I have been fixing this car up since I bought it, and finally got things all buttoned up correctly, ie fixed wacky vaccum leaks that were misc hoses under the dash that lead to nowhere, that were impossible to track. and you name it wrong with a swap I've fixed it. Motor itself and everything else are in amazing condition and really low miles. I got the cat, passed emissions with flying colors, got it retuned, things had been fine, then all the sudden I'm fouling plugs at a rate of 1 set a week roughly, so I went 1 step hotter, then yet another step hotter. The car already ran a little rich even after tuning, and seems like it just gets worse everyday. It's not detonating, but bogging, the sounds are massively different.I don't know if this needs to be moved, I was in a hurry to get this out before work.
nothingFancy
Car: r34
from what make and model car will coolent temp sensors *both sensors* will fit on the sr20det redtop? i bought 1 from a 91 sentra ser last nite but its bigger then the sr's
Eric-RPS13-
Car: 240sx
easiest way to find out is visit a napa store, and on the "gray screen" ask to see the application list, and you can see all the cars the part goes onto.
Nissan786
Car: 89 180 Red top sr20det
moyea
Car: Paddle Shifted 92 240SX SR20DET, 02 Frontier S/C, 90 240sx ITA
Anybody know the size, thread/pitch of the spark plug/coil pack cover bolts on the S13 SR20DET?
Slipstream
Car: '94 Sonoma, '90 300zx n/a
52F on cylinder head, red top or black top S13, and if so what year range?
Eric-RPS13-
Car: 240sx
prolly 6x1.00
onecrazyfoo4u
Car: 03 Type S
Just take one in to ace or tru value and get 4 new ones, try not to strip them, I have one that sheared off in the valve cover. Nothing works to get it out either, including the extracter sets, it sucks!
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
15238-52F01 is the part number for the oil filter block that is located under the intake manifold between the alternator and starter.
what i want to know is if this is the same part as an FWD NA SR20?
grmreapr
Car: 89 rps13, 02 mazda protege
anyone know the part number for the silvia k spoiler
grmreapr
damn well lets go with both make it easy I cant remember now
grmreapr
awesome thanx and where do you get these wonderful manuals I would have a field day
Modified by grmreapr at 2:35 AM 11/29/2007
zrowkewl
Car: 1989 nissan 240sx
so let me just get this straight..with the part numbers given..i can just go the local parts store and give them the number..and boom..ill get that part??
duffman1278
For example: S13 Spoiler on the left: K6030-35F25 just give them this number "K6030-35F25 "
zrowkewl
so if i wanted to get the part # for all the belts on the sr id have to go with the jdm stuff right?? or am i wrong
Nissan786
cheapspeed wrote:a 95 and up alternator will bolt to a s13 sr with some slight modification to the tensioner mounts
How much do you need to mod the tensioner mounts to get it to work i think my alternator is suspect.
beobe99
Car: 99 Impreza RS GC8 with 2002 WRX enigine Swap!
hey speedracer1
could you send me the file you have on part #'s? i would really appreciate it. I work with a company shipping in JDM engines and of course we come accross one or two that need a part.
thank you very much in advance.
[email protected]
Bob
