SR20DET Parts Guide
guilty_coupe13
Car: a S13 coupe
hurddawg wrote:take your gates part number to any parts store they will get you the proper belt.
I did this at my local place and they gave me Dayco belts and they worked fine. The guy told me that part numbers for belts are standardized. So they can cross-reference them easily.
K050370 AltK040345 P/S
K 05 0370....05 indicates # of ribs, 0370 indicates length of the belt. K signifies its made my Gates.
that for S13 SR20DET only or will those belts work for S14 SR20DET???because I need a power steering belt for my SR (which is a s14 sr20det)
Slipstream
Car: '94 Sonoma, '90 300zx n/a
Anyone have the part number for exhaust valve guides? Need some fast.
574-240sx
Car: Nissans, Toyotas, Subaru
That will work for a S14 SR too. If you have Greddy/Unothodox pulleys you need a 3 rib belt which is next to impossible to track down. I'm in the process of tracking down one right now and it seems to be a pain.
streetspirit7
Car: '97 240sx
Anyone know if the 87 300zx turbo O2 will work on an S14 SR?
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
streetspirit7 wrote:Anyone know if the 87 300zx turbo O2 will work on an S14 SR?
EDIT: I found this when searching the intrawebO2 Sensor (S14 SR20DET BLACKTOP)- 95 300ZX TT
Also, this is what Phase2's site says about the SR O2 sensors they carry:
OEM S13/S14/S15 SR20DET O2 Sensor
OEM Nissan NTK O2 sensor, great replacement for the worn out ones that often comes with the used SR20DET motors. Change it to improve your gas mileage.
For S13 models, there's 2 type of O2 sensor. FAT (Blacktop) and SKINNY (Redtop) type, both of which are 3 wire O2 sensor. To be safe, please look at your O2 sensor to determine which type you have and order accordingly.
So I think the fat type that everyone sells is used in the S14 and S15 as well, but I could be wrong and that doesn't answer your original question but should provide you an option if the 87 300zx one doesn't work. IF you go a sponsor check under OEM SR parts.
Modified by homeslicej2 at 5:03 PM 4/18/2007
homeslicej2
boostedkouki wrote:Is there a usdm equivilent pcv valve for the s14 sr20det?
Phase2motortrend.com sells them for all the SR motors (S13, S14, and S15) under their OEM SR parts section. I don't know if any of our other sponsors do or not.
Modified by homeslicej2 at 4:46 PM 4/18/2007
homeslicej2
guilty_coupe13 wrote:What will work for a throw out bearing for S14 SR20DET? I've herd 93' 240sx and 93' Sentra SE-R does anybody know for sure what will work?thanks
Again, Phase2 has OEM throw out bearings. They have them for both the S13 and S14 SR's. I'm sure some other sponsors have them as well. Check under OEM SR parts.
homeslicej2
Slipstream wrote:Anyone have the part number for exhaust valve guides? Need some fast.
Only part #'s I can find are for exhaust valves, valve seats, valve oil seals. That's it though. I found a huge list on another site and they credited it to NICO member SpeedRacer1, so you can try to contact him and see if he knows the part #. You may have to just get the Tomei or JUN ones.
xpicer
Car: 1990 nissan 240sx
upper rad hose for a sr on a s13 , i used a 1999 nissan quest lower rad hose and i added the thermo switch , it worked great with my electric fan set up
jin3001
Car: 95 &97 240sx
do you happen to have the part # for the factory ac hoses used on the s14 sr20.i need both compressor hoses high and low pressure sides.i have the compressor ,it part#dkv14c and has a four rib pulley.please help me if you can you seem to have a vast aount of sr information.thanks in advance.
9sec240
Car: S14.5 Turbo KA
Earlier in this thread, it was stated that JWT said the DE rings will work in the DE-T. I have DE rings here that measure different on the second ring depth.
They will fit in the groove but I dont want to break the package open unless I know they can be used for sure.
Has anybody used the DE rings in the DE-T?
CoupedUp
Car: 1993 Coupe
Crossover Radiator Hose for KA24DE Radiator with SR20DET
Gates P/N: 20893
For all of you who would rather pay $10-$12 instead of $30+ at other places.
RockAuto online has them and im sure your local parts store does too.
Timtiminy
Car: 89 240sx fastback
Looking for U.S. equivalants for SR20DET Radiator hoses. The KA lower radiator hose works on the SR20DET (with trimming??) correct? Is it the KA24E or KA24DE or are they the same? Has anyone found out if there another car that has a similar upper radiator hose to the SR20DET that maybe just needs to be trimmed? On a side note I bought the heater hoses for the SR20DET swap from XAT Racing and I am going to try to find out if they match up with any application when i go by napa.
WestCo Justin
Car: S13 coupe
Timtiminy wrote:Looking for U.S. equivalants for SR20DET Radiator hoses. The KA lower radiator hose works on the SR20DET (with trimming??) correct? Is it the KA24E or KA24DE or are they the same? Has anyone found out if there another car that has a similar upper radiator hose to the SR20DET that maybe just needs to be trimmed? On a side note I bought the heater hoses for the SR20DET swap from XAT Racing and I am going to try to find out if they match up with any application when i go by napa.
Upper radiator hose and lower radiator hoses are JDM part numbers only and are available through dealerships such as ours that stock JDM parts in house.
We currently have the lower hoses in stock, upper hoses on backorder.
SR S13/S14/15 upper radiator hose 21501-65F01SR S13 lower radiator hose 21503-52F01
Timtiminy
I know that the hoses are jdm only for the actual part. i was wondering if anyone has found a non jdm (any auto manufacture) hose that works either in its original form or cut/modified. Oh an i believe that the 91-94 dohc lower radiator hose does work for the lower hose on the the SR20DET I think you just have to cut a little off (can anyone confirm this?)
JasonDMX222
So, what all year Sentra/G20 AC compressor and bracket will fit the redtop sr20det correctly?
nissan_s15_240sx
Car: '92 nissan 240sx with s15 silvia front end conversion
Anyone know an oil pan US equivalent for the s13 blacktop?
I need to be able to find this at AutoZone or Advance Auto Parts, the nearest Nissan dealership to me is over 100 miles.
Thanks!
homeslicej2
JasonDMX222 wrote:So, what all year Sentra/G20 AC compressor and bracket will fit the redtop sr20det correctly?
sorry, but . Never heard of this.
nissan_s15_240sx wrote:Anyone know an oil pan US equivalent for the s13 blacktop?
Thanks!
No, but several of our sponsors carry the stock S13 SR(red or black top) lower oil pan for ~$90 and can ship it to you pronto.
nismo newb
Car: 2 liter 90 civic hatch, and soon to be sr swapped s13
i need info on all of these. i got a used s13 blacktop swap and the guy lost all the transmission bolts. im entirely new to nissans in general so i need washer sizes and everything, thanks.
transmission bolts (minus the washers):08171-2701A need 1, not available in US08171-2651A need 2, $0.8308171-0601E need 2, not available in US08171-0301E need 1, not available in US08171-2801A need 1, not available in USFor the bolts you cannot get in the US, just get some of the right thread pitch and length.
nismo newb
SpeedRacer1 wrote:Only S13 SR20DET waterpumps fit S13 SR20DET's. Only S14/S15 SR20DET waterpumps fit S14/S15 SR20DET's.
A good deal can be found here...http://www.courtesyparts.com/M...ET-WP
they are out (link cited)....andddddddd
Movingviolation240 wrote:Water pump 21010-52F00 (SR20 all)
nismo newb
SpeedRacer1 wrote:Try getting it off ebay then...http://cgi.ebay.com/ebaymotors...wItem
or
or
or
And I am not sure what Moving Violation meant by that but I am pretty sure he passed away so you cannot ask him now.
damn that sucks....
i reeeeeeeeeaaally need the sizes for the transmission bolts....its the only thing keeping my sr out of my hatch.
nismo newb
can you not pm on here?
if there is any way you could make sure they are for a rwd sr transmission and you want to sell em let me know. did you happen to have the washers too?
nismo newb
SpeedRacer1 wrote:No email on this forum, email *edit
nvm i just bought some on ebay. thanks anyways. which oil filter for an s13 blacktop? can you use one from a early 90's se-r? im just verifying...
Modified by nismo newb at 4:53 PM 6/22/2007
RuthlessRPS13
SpeedRacer1 wrote:It is a combo of measurements on the block and the stamping of the block itself. I have a bigger version too if you cant read this.
could you email me a bigger picture of this please
thanks
[email protected]
soka
Hi
I need to replace the banjo bolt washers/gaskets for the oil and cooing lines that go into a t28 turbo for a kouki s14 sr20det.
I've searched around the forums and found one post where the guy said you can use the hardline washer/gaskets from a 300zx tt but he didnt give any specific part numbers.
Does anyone know what the part numbers are for those?
I need them for the 17mm and the 19mm banjo bolts.
are these the same things?
I went to the dealership the other day and the person at the parts desk didnt understand what i needed... Hopefully if i can go back with more specific information they will be able to help me.
Ive also tried to find them for sale on the internet but no one seems to carry them. i guess they all assume they are easy find.. >_<
thanks for the help!!
Nissan786
Car: 89 180 Red top sr20det
So ok i just swaped out turbo elbows to the megan racing one. but im wondering if i need to keep the piece from the oem one......it looks like its for a vacuum line. HELP PLEASE I NEED TO KNOW.
homeslicej2
Right forum, but wrong thread to ask this in. After you try searching for your answer using the NICO SEARCH button at the top, if you still can't find your answer, then create a new topic in the SR forum and ask this question. Please try searching first though and welcome to NICO!
jackman240
Car: 240sx SR20
the shop i got my sr from gave me two harnesses one cut before the ecu and one with an ecu hacked up somewhere else, i checked the part number and the ecu is from 94-96 pn 23710-50F05 will this work if my motor is 91-94? some of the wires are diff colour too, whats the deal?
PS good post, helped me get alot of stuff sorted out. thanks!
jackman240
Car: 240sx SR20
if the o2 sensor wiring is different but im using a fuel computer such as apexi safc then it shouldnt matter, or will i run into more problems if the wiring is messed
nismo newb
i need the sizes/specs for the banjo bolts for the water and oil line. also if there are any same size parts that can be substituted from another vehicle let me know. also where would i find such parts other than a junkyard or dealership (cant really afford to wait for shipping, or searching all over the place for a possible match)
this is the only thing keeping my motor out of my car right now and i need to pick these up in the morning. thanks.
