If it needs coolant added then it's going somewhere, either into the motor, or leaking out. You should fix it before it causes overheating, otherwise you could damage the motor hwich I'm sure you don't want to do.KRPSICHI3 wrote:My car always seems to need coolant in the resevoir but, the engine never overheats.
