OutToWinPAHC »
https://forums.nicoclub.com/outtowinpahc-u66900.html
Thu Aug 12, 2010 6:18 am
Low compression, over heating.... yeah I would say warped head / gasket, and a possible leak in the system.
I would rent a coolant system tester set to 1.5 bar and see if it hold pressure. If it doesn't search for the leak. If you cant find an internal leak then check for intermix, and if there is some pull the head. Check the the decking, have the head checked and milled if needed, and then get some new head bolts / studs and a gasket set.
