Chaluska wrote:definatly check out if the thermostat is opening up or not, its possible to get a defective one from autozone/nissan/advance auto where-ever.
wait, did you say you have 1- 14" fan?
thats definatly not enough, the radiator is like 29" across, the 14" fan only covers half of that, the other half is not being cooled, and will eventually let enough hot water by to overheat the system.
the radiator needs to have solid airflow across ALL OF THE FINS, not just half. snag another 14" fan, or get a set of altima/maxima fans, or a taurus fan.
The funny thing is that it's overheating on the freeway and NOT in the city. Technically, you dont even need to run a fan on the freeway; at 65+ mph you're probably blowing through more air than one fan. If its over heating all the time or just in the city then I could see your reasoning, but since it's not, your "1 fan is not enough" claim doesn't make sense.
Op, hows your radiator cap? is it holing pressure? Either way, it sounds like you have air in the system. Bleeding it out can be a b****, i know it is for rbs, so you might want to invest in a swirl pot.
