Sr20det Overheating, Help !
SR BEAST
HI guyz,,,
after installing Trust intercooler on my sr20det black top,, when i redline and go for top speed, the car overheats like crazy,i didnt have this problem when i had the stock tiny intercooler,,
some people told me that the small custom piping i have done to connect the intercooler to the turbo and the intercooler to the throttle body is causing this problem,,,so wat do u think guyz,i have 2 inch intercooler piping,,does this size cause the overheating problem??,,cuz i saw my minifold the other day, and it was glowing red !
and what is the recommended intercooler piping for a 19" front mount intercooler ?
thanx
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
The problem is that the front mount intercooler blocks alot of the airflow to your radiator. Intercooler piping has nothing to do with a motor overheating.
Supafly
SR BEAST wrote:HI guyz,,,
thanx
tell "some people" to go jump off a bridge.... like j-spec said, the intercooler core blocks airflow through the radiator. get a better radiator, fan, or just plain cut some vents in the bumper to make the air flow past the intercooler and into the radiator.
goldollar
Car: cars
Quote »some people told me that the small custom piping i have done to connect the intercooler to the turbo and the intercooler to the throttle body is causing this problem,,,so wat do u think guyz,[/quote]
Man gotta love peopel who know it all. :rolleyes peopel need to learn to not say anything when they dont know what they're talking about.
SR BEAST
thanx guyz,, and i;ll pass on ur message to these people !;)
but,,can u tell me whats the best size of pipe should i use for my FMIC ?
Onizuka
2 inch is fine.
SR20_N_KC
I have the same problem in the summer. I have cut and taken the bumper completly off my car and still overheated (according to the stock gauge) down the highway in the summer. I have added dual flex a lite fans that run all the time. I also added a auto meter water temp gauge and it read about 210 when the stock gauge was up close the the H. I have spoken two HT and Phase 2 and they have not seen this issue. A shop here in KC said that it was the temp sensors. However HT said NOT to swap the temp sensors from the KA to the SR. I am in the process of installing a Koyo before the spring. We will see how it goes when it gets warmer out. Good luck man. I feel your pain.
xxtrizz
Car: Cars, computers
I read somewhere that the sensor for the Heat temperature in the dash could be off if you swap like a s14 into a s13 but im not sure that is your problem at all. Just wanted to give you heads up.
