SR20DET or turbo KA24DE
ST240
Car: RB30DET Nissan S13
'01 Nissan Pathfinder
Which would be more expensive and/or which one is less hassel!
A decent turbo kit costs about 4000 for the KA24DE. On http://www.srswap.com they said to do the complete SR20DET you need all this:
$2400 SR20DET engine and 5 speed transmission$80 - $200 Shipping$309 - $339 Performance clutch kit$139 - $229 3" downpipe$849 - $999 Intercooler Kit$129 - $220 Blow Off Valve$129 Hi Flow Fuel Pump$390 - $650 60mm - 80mm full cat-back exhaust$55 K&N filter and aluminum intake adapter$50 Motor oil, PS fluid, transmission oil, coolant$99 Radiator hoses and heater hoses, belts$35 Oil filter, fuel filter & plugs$14 Heat wrap tape
This all adds up to way more than 4000
But like im wondering if you need to shell out all this money right away. Can't you just buy a front clip and transfer it all into your own 240sx and have it run properly without all the above? then later just upgrade stuff as you go along?
Thanks,
-Andre
240man
Car: Aerospace
I've got a T3/T4 with a custom manifold, Apexi intercooler, all the IC pipes, 550cc injectors, JWT ECU, all the fuel and oil lines, and everything else your going to need for the KA turbo swap. It also includes the autometer boost and fuel pressure gauge, and a Greddy EGT. I've also got the Greddy Profec B and a Blitz turbo timer that I'm throwing in with the kit. This settup will put you over 300rwhp.
I'm asking $3100 for the whole settup,
[email protected]if your interested
I H8 UR DSM
depends on what you want from your car. throw a turbo kit on your stock motor, your not running too much boost, but if your just looking for a little more power then just 'toss that puppy on there"...:rolleyes
Nismo_Freak
Car: 89 Nissan 240SX
Hey.. talk to Dauntless about the SR and the parts, he may be able to help you out with a package deal. Tell him Nismo_Freak sent ya.
