Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Mon Oct 29, 2007 7:53 am
The transmissions should be the same between a DE and DET, except maybe 5th. The SR20DEs might share the same 5th gear as our KA24DEs, but that's not even that different. The DET's 5th gear just helps keep the rpms up a few extra hundred to help spool the turbo while cruising.
Automatics are a different world entirely for SRs. They should work better on a DE than a DET because of the way a turbo works. An automatic transmission should have more turbo lag than a manual because of the way the auto shifts. However, once the turbo spools up, the DET will outrun the DE through the extra gained power.
I do apologize, though. I'm having a difficult time understanding what you're asking.
