SR20DET oil tube (bolted on top of the cams)
HollywoodJackson
Car: 2004 Infiniti G35
1990 Nissan 240SX Hatchback
1990 Nissan 240SX Coupe
Greetings fam,
I'm rebuilding an SR20DET that I purchased while it was unassembled. I have a quick question about the oil tubes that bolt on with the cam shaft bearings. I've watched a few videos of the process on YouTube. I noticed that in the videos, each oil tube also had a metal piece that bolted on with it. Sort of like a small shield. I don't have those pieces. I only have the oil tubes. I've seen some images online, that also show the oil tubes installed without the metal pieces. Do I need those metal pieces, or can I just install the oil tubes without?
Thanks
HJ - I looked at a ton of pics (including from my own builds) and didn't see the "shield" part you're mentioning. If you find a pic, post it up.
HollywoodJackson
AZhitman wrote:
Tue Aug 30, 2022 6:20 pm
It was in a YouTube video. I could have seen something else. I couldn't find it again. I see several more videos, and what ever I thought I saw I can't find it now!
Thanks :taz:
