Schassis/raw »
https://forums.nicoclub.com/schassis-raw-u220140.html
Sat Jun 22, 2013 5:06 pm
Ok so here's an update a little bit of insight is gonna be needed on this . Ok I installed my oil gauge and on first start up the oil light came for a second this is on a cold start over night I made sure the head was still wet before starting it up . When I started it I had the oil cap off to see the cam tubes they didnt start spraying on start up it took a second and then normal flow . As I was installing my oil filter I could see two nice dents right in the middle of the pan right where the pick up is took off my pan , and I on the pick hole some of it was dented as well could this be whats causing my hestitant oil pressure problem and also at full temp at idle oil psi was at like 14psi and at 3k rpms its a like 55 to 60 psi . AND IS MY ENGINE F$&@ED because of this weird issue I really hope not ? I really need some advice on this please !
