Sr20det Oil filter
TonyStarks29
Car: 1994 Nissan 240SX Convertible w/ SR20DET
i do an oil change on my SR it takes me an hour to do everything because i cannot remove oil filter easily, removing the filter usually takes me an hour i cant seem to ever get a good grip on the F@#%ER! i use the oil filter wrench (isnt long enought and i cant get a grip.... what do you guy use becuase any tool i use to remove the filter isnt working because its not long enought and i never can get the correct angle i need
and here comes the flaming....
Hijacker
Car: '92 240sx Convertible
'94 F-150
Either switch to K&N filters for the 1" nut on them, or you can get a filter wrench adapter. The latter are the deals that fit snugly on the end of the filter and allow you to get a socket on them.
mRodiek
Car: Stock Hatch
Oil filter relocation
TonyStarks29
sweet all K&N filters have that hijacker even the 91 SER senta filters? a socket would be lovly
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
DriftBoy07 wrote:Oil filter relocation
Second that, saves me 20 min every oil change and a hell of a lot of aggrivation. Also, has fittings for oil cooler which saves me headaches at the track.
TonyStarks29
how much does an oil filter kit cost?
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
QFT
blacksrjdm
TonyStarks29 wrote:how much does an oil filter kit cost?
Google search it. Oil filter relocation kit. There are 50 companies that sell them. I have the circuit sports, works great and works great with my cooler.
TonyStarks29
my next oil change ill try the K&N filter if it doesnt take forever to remove ill stick with that if not ill problly do the relocation
maj Andres
Car: Zenki, '95 Model, w/ S14SR20DET
Have you read this one? zerothread/167442
Jybfan04
Car: 98 Nissan Altima
91 Nissan 240sx
Nice read...
240trackjunkie
Car: 1990 Nissan 240sx
Removing the intake manifold support bracket helps a little. Hopefully that bracket is something Nissan put on there just for looks ... I've been running without it for a looong time.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Alot of people told me not to even put that intake manifold bracket back on the block when I was prepping my engine because of this exact problem with it getting in the way during oil filter changes.
JaxS13Racer
Car: 1993 SR20DET S13 fastback
Go with the K&N filter, it's a better filter than most and is way easier to remove. I was so happy when I found them.
slow s13
Car: cars, photo, music
if you cant get it off by hand your putting it on to tight to begin with
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
You can punch a hole in it with a screw driver or try using a pair of Channel Lock Pliers.
