SR20DET - Oil Catch Can Return Line Removal from Block
BoostMunchies
Car: 1990 Nissan 240sx
Hi, I am in need of some help. I have my block at the machine shop and I didn't remove the two lines on the block, one is a factory return and I am unsure of what the other one is. The block cannot be decked with them on there and I don't know how to remove them. I have one picture of them but isn't the best quality. Any help is greatly appreciated.
Thanks
blkvrtswp
Car: 93 240SX Convertible
SR20DET FP 20G Turbo
I believe they are simply pressed into the engine. Tap and rotate gently, they should come out.
2_Liter_Turbo
Car: _________________
'96 S14 Coupe: SR20VET
'90 R32 TH1 GTR: RB26DETT
'92 S13 Fastback: SR20DET
'11 V36 Sedan: VQ25HR
'06 GMT800 2500HD: LBZ Duramax
Whatever you do, DO NOT remove the coolant hard line (bottom right circle in your picture). You can deck the block just fine with it in there. It is next to impossible to get it to not leak once removed. The machine shop that did my first build did not know this, and they removed it. I couldn't get the thing to seal at all. I tried EVERYTHING, lol. My new motor was decked with it left on, and no leaks. If the machine shop says they cant do it, then take it to a different shop. The upper left circle in your pick is the air/oil seperator tube from the bottom end. Just grab it tight, and move it back and fourth. It will come out fairly easy. Just make sure you re-install it before putting the head on... made that mistake a long time ago... ha ha.
