sr20det o2 sensor wiring
okinawa drift
Car: 89 240sx SOHCoupe
ok so i noticed im not exactly getting the best gas mileage, and my car idles at about 13-14 on the wideband, i unplugged the O2 to see if it would effect anything, plugged it in, still continued to idle in the 13's
i have searched, i can't find a straight forward answer
i think i may have a blacktop wiring harness which is for the FAT o2 sensor, and i have a skinny o2, i heard the wiring is pinned out differently..
on the the sensor side there is a white, black and red wire.
-white is going to the black wire on the harness
-red is going to brown wire on harness
-black is going to what i believe is the white signal wire on the harness
everything check out?
i tested to see if any of the wires were getting power, and the red wire on the o2 is hot
zachattack_5491
Car: Pignose S13 Redtop SR
What brand of sensor are you using? While reading up on the subject a couple weeks ago, I found that different manufacturers use different wire colors.
Wiring Specialties
Vendor
The blacktop ECU (E5) has a separate ground next to the injector signal wires (its brown/yellow). The redtop harness grounds the o2 sensor straight to the ground. If the two a mixed up, you might see some slight mileage issues.
