Djinfinit »
https://forums.nicoclub.com/djinfinit-u79738.html
Thu Mar 24, 2011 6:13 am
Well, heres the deal.
I had a another harness in there and stupid me had taken of all the factory tape from the harness near the ecu plug. What i mean by tape is the tape over crimps ect. Well by doing that i guess the chassis grounded out or something and burnt my fuel injector drivers on the ecu(the diode on the ecu blew). So i decided lets go with a fresh harness, so i purchased a harness from a local member and he assured me it was pre-wired and worked perfectly well that was a lie and i had to re do some stuff. I put a j30 ignitor and the dash connector from my old harness on this one, and finally had to replace a broken ecu connector. Yes, stupid me again. Now prior to removing the old harness the car would turn over fast and everything with a battery i was using, but when i installed the new harness the car wouldn't turn over(crank) at all. Considering i tend to say i have fairly decent knowledge of the 240sx (owned 4) i was stumped at why it wouldn't start, or even crank for that matter. I was expecting a turn key start. So, i once again started searching and searching, and eventually began giving up on this car. I decided if the starter was fine all along it had to do with some sticking relay or something. So i kicked my dash and there it went the car started turning over. Now don't get excited, it turned over slowly not like a fully charged battery that i took out of my integra that was in an accident. I was like wtf? and on top of that the jumper wires became very hot quickly:s. So here i am alone with no car and its getting closer and closer to summer and my poor little car isnt running. So, i dont no if the ecu flickering is because of a weak connection on some wires, the starter relay not clicking over completely or battery. Theres also a squeal almost like a grind when i crank so i dont no if something is grinding :S? it wasnt a problem with the other harness
If anyone can read that and see if it helps that would be awesome.
pyroniak im really looking forward to your answer, no one elses seems to want to help:(
Djinfinit on Thu Mar 24, 2011 7:53 am, edited 4 times in total.
