SR20det, not lined up???
siks13sr
Car: 91 hatch. RB in the works.
alright... i put my sr20 in today an it was hard to line up the motor mounts but i finally got em in... i put the transmission crossmember in place then i went to put the shifter back in an the transmision is moved to the right side a little... i dont know what is wrong... i need some help tryin to figure this one out........
Silvia007
Car: 93 Nissan 240SX SE Fastback
Yeah, my buddy had 3 swaps earlier and they all did that, even mine. Weird.
siks13sr
do you know how to correct that or does he?
HailtotheSilvia
Car: 93 S13 coupe
Dude, did you remove your AIV unit? If not then it will most likely sitting on your Steering rack and cause it to not lined up. I removed my later and fix the problem
siks13sr
No i didnt remove the aiv unit. I was going to remove that but i decided not to right before i put the sr in. If i remove the whole aiv unit, theres a hose going down to the wastegate i think, do i remove that also and just let that off of it or what? Thanks
HailtotheSilvia
Car: 93 S13 coupe
The AIV pipe runs back to the Turbo outlet, the pipe is what sat on my steering rack. I just took the whole damn thing out and capped it with a plug and it works fine for me
siks13sr
i removed my aiv unit an pushed on the engine an it sliped right into place no problem.. Thanks
