sr20det got vids and pics no oil pressure?
slipnslide240sx
Car: 240sx
hey guys i started my 240 with sr in it today and drove around the block it drove and pulled hard still, after parking in the drive way i herd a knocking noise.
i went ahead and uploaded the video i made.
[youtube]http://www.youtube.com/watch?v=HhaZQvglW20[/youtube]
i have a 90 240sx with a s13 redtop. i looked under the hood and found oil leaking
it look like it came from the main pulley.
also i notice white smoke out the exhuast. only when i reved up the motor
this is the start to a bad day! please help
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Knock knock! is your car slammed to the ground? check your lower oil pan, the pick up might have got dented. Sounds like rod knock to me, park it and pull it and fix it. The crank shouldn't be too fubared right now.... well at the time of the vid.
Hijacker
Car: '92 240sx Convertible
'94 F-150
Did you replace the front and rear main oil seals? Those should be done before the motor goes in. I've seen a lot of those come into the states bad just from sitting and rotting in a yard.
Hoffman5982
Car: '95 sr20det 240sx
yeah, that motor will be coming out soon. Unless it was a very bad leak, to run out of oil just driving around the block means there wasn't much in there to begin with
