sr20det noise
black240sx96
Car: cars girls motorcycles and bmx freestyle
i have a problem with my sr20det s14.....i just got my 3' cat back exhaust and i took the car out for a test run....not boosting high or reving or even speeding...just a normal drive.....everything was going good so i kept driving around...well about 10miles later i hear a rattle....i pull over and the exhaust starts smoking white smoke....after about 2-3 mins(of just sitting in the parking lot) i turn off the car...i dont have a turbo timer and this was the first time i ran the car....i let it cool down and i turned it back on and the rattling sounds like its coming from the turbo....i took the piping off and i didn't feel as much air coming from the turbo as normal.....so the rattling continues but it stops smoking....any ideas ??
black240sx96
ok...i took the turbo off and i noticed that the turbines are not only spining on its axes but it seems loose and moving up and down...im guess this is why i had that rattling noise.....but what would have caused my turbo to do that and can i fix it ??
180fan
Car: 89 fastback
shaft play, time for a rebuild.
black240sx96
i have never rebuild a turbo so what is it that i will need to rebuild it....besides tools???
nuts510
Car: sr20det 95 240sx, rb20det 93 240sx convertible, 78 280z turbo, 71 ca18det datsun 510, 72 scout,88 CR
it's really best to let the people who have the equipment rebuilding turbo, if you're interested there's a local shop here in Roanoke Virginia that's been rebuilding Turbos for me they are a garret rebuild station but specialize in trucks they get a kick out of my little Turbos they do a good job and if I bring on the center cartridge parts and labor is usually under $300 so if you're on a budget to good cheap way to go, and the turnaround times usually very good. Good luck
