brianphung »
https://forums.nicoclub.com/brianphung-u62425.html
Sun Jan 18, 2009 5:20 pm
I recently purchased an SR20DET S13 for a winter beater, and drove it for a few weeks with no issues. Before I drove it however, I fixed a left rear wheel bearing, put aftermarket turbo back exhaust on, and changed the O2 sensor (not sure if this is relevant but I decided to say it anyways). Last Thursday, I drove it to work with no issues. When I went to start up the car after work, it just cranked and didn't fire up. So I started diagnosing. I had no spark and no fuel injector pulse. Turns out the guy I bought the car from didn't solder the ignitor connector, just twisted and taped them. So I soldered all those connections (he had a Z32 ignitor if it matters, with a couple wires doing nothing). After doing so I had spark, but still no fuel injector pulse. After a long weekend of diagnosing the MAF, CAS, TPS, CTS, and all wiring, everything turned out to be in working order. But I still had no fuel injector pulse. I decided to start replacing parts. Tried a buddy's ignitor, with no change in symptoms. Tried another ECU, figuring the injector drivers might have gotten burnt by the ignitor wires grounding out, but this was not the case. So here I am, on a Sunday night, with a broken car. If anyone has any suggestions, I am very open to them. Thank you in advance.
P.S.: I have gone through all the diagnostic procedures in the FSM for the injector, CAS, TPS, and most other circuits, but nothing seems to be helping.
The setup is a stock SR20DET blacktop, only modifications are an FMIC and a Koyo radiator. The car also has a remanufactured ECU part number 2731M 50F05. There is no provisions to read codes, however on my friend's ECU that I tried it flashed a 55.
Edit: Forgot to mention I am getting 12v (maybe 11.8) to the injectors, and the wire that goes from each injector to the ECU, all of them have continuity, and not shorted to ground. Also, I have lots of fuel pressure. The car will start fine with starting fluid/ether, so I believe the only issue is the lack of fuel injector pulse. TPS also tested out to be fine and not entering clear flood mode.
