Didderson wrote:Once you learn to use rtv correctly and prep the surface for a new silicone gasket, you'll wonder why they don't use this stuff everywhere else.
Trick is to getting a clean surface thats not greasy or oily or has old rtv on it, installing the new one, and waiting 20 mins til you torque it down so it has time to set.
My plan was to apply it, Tighten it and torque it and then let it set overnight or for a few days since i need more parts anyways before it will be running.
I'm really trying to figure out what sealant to use for all the coolant parts, like the thermostat housing, and thermostat housing where it attaches to the block as well as the water pump and upper hose outlet...
