DrifterProdigy85 »
https://forums.nicoclub.com/drifterprodigy85-u30257.html
Wed Oct 10, 2007 2:35 pm
A guy named Gatecrasher on Fresh Alloy ran a 50 or 75 shot on his 2871R .86 SR20. Used an Enthalpy Tune, 740cc Injectors, and Wet Shot. Always go with a wet shot because it will automatically mix the fuel in with the nitrous giving decent AFR. Stock Bock SR, i dont think id run more than a 50 shot to be safe. Mazworx ran a 150 shot on there built SR20, but that was with like 45psi from a T88 too. You could most likely run more if you tuned for it and ran lower boost of course. Another thing, a good rule of thumb is for every 50 shot after the first 50 to retard timing 1-2*. So 50 shot can stay 15* (stock), 100 shot would be 13-14*, 150 shot would be 12-13*, and so on.
