sr20det neovvl head swap question
areda32
Car: Trying to build a 240 sx beast
im doing this swap almost ready to start assembling..as per the install and firewall clearance I fully understand to make it fit and the custom manifold and stuff okay cool got it..but what im a lil confused is the electrical portion. im obviously going to run an aftermarket ecu and get a new harness but do I need to know anything really important regarding the electrical I couldn't find a good writeup in any forum about a complete swap from soup to nuts. if anyone could shed any light on this for me Id really appreciate it..or any reccomendations please as to parts and what i should run possibly..i know theres alot i need to learn in a short period of time so all the helps appreciated
2_Liter_Turbo
Car: _________________
'96 S14 Coupe: SR20VET
'90 R32 TH1 GTR: RB26DETT
'92 S13 Fastback: SR20DET
'11 V36 Sedan: VQ25HR
'06 GMT800 2500HD: LBZ Duramax
It depends on how you want the VVL to engage. If you want separate control between intake and exhaust (like factory), you'll need a way to switch the solenoids independently. If you just want both to switch at the same time (like an older honda), you just need one switching source. The solenoids share a common 12V power source and are switched by ground. Most stand-alones will have a "V-TEC" switching option, this is where you'll need to hook it up. If for some reason your ecu does not, the MSD window switch is a popular option, but you'll need two if you want independent switching between solenoids. Other than that,the wiring is pretty much the same.
