RFcool »
https://forums.nicoclub.com/rfcool-u27691.html
Sat Jul 10, 2010 2:33 pm
Sup guys, just picked up this car has a sr swap in it, and is missing on a cyclinder. Vaccum is good, havent checked timing yet, but i do know how to do the whole take off the cover setup to TDC and all that crap. Anyhow so i went on with the simple options.
this is the first cylinder closest to the front of the car. Pulled coil pack, no change in engine or idle. Swapped coil packs with ones that worked when i did it to all the others same difference. So i know its not a coil pack. Took the coil pack out slapped a plug in it and tried to ground it and no arc from plug to ground. Checked the injector sequence in same manor and no idle change when i disconnected the first injector, but did change idle and sound when i disconnect the others. So at this point any ideas of what needs to be done. I know to do a compression test but i dont have a tester here laying around. But if i did do a compression test what should the cylinders sit at? Also if i was to hook up an ohm meter to it what shoud it read on ohms and how to connect it.
I used to know how to do alot of this s*** but its been 2yrs since i dabbled in one of these so my info from computers is lost and my know how is gone as well. Maybe post up some links or give me some direct answers. AND YES I KNOW there is a SEARCH button.
