Norcal510 »
https://forums.nicoclub.com/norcal510-u34929.html
Tue Sep 23, 2008 6:13 pm
Hello All,
Im back with questions. I finaly got the replacement motor!! Complete Sr20det motor that came out of a car equipped with a automatic transmission.
Well, based on what everyone said above the install should be very straight forward. However I did notice a few differences in the motors. The motor I currently have in my Silvia (zenki) is the original motor that came with the car. From what I was told the motor Im going to swap came from a 97 Silvia.
One of the difference I notice is the throttle body has one connector and the other motor has two? Could someone tell me I need to swap throttle body? I've posted pictures of both motors so you can see the differences.
My current motor
The replacement motor
The other difference I noticed the replacement motor has a tube that runs from the exhaust manifold to the intake manifold. Im not sure if this is an EGR valve? And would I need to change or block these off? would there be an difference if I didn't change it?
Also is there anything else anyone could think of that I might need to change?
Thanks again!:biggthump
