aaronscomp »
https://forums.nicoclub.com/aaronscomp-u88194.html
Wed Jul 28, 2010 5:16 pm
Ok so ive had my built sr20det in for like 2000 miles now it was running great idleing great then one day on my way home from work it started to miss fire as soon as it goes past 3,000 rpms. Ok ill tell you the mods first its a sr with a 57trim turbo bottom mount set up on 10psi boost, stock ecu and stock injectors. Ive replaced ecu,maf,wireing harness, coil packs, spark plugs, fuel pump, fuel filter, igniter chip, cas , injectors, throttle body with tps. Im totally lost now i thought one of those things would solve the issue any help would or pointer would be great
