Yasko »
https://forums.nicoclub.com/yasko-u150766.html
Mon Jul 04, 2011 8:01 pm
What do you guys recommend on replacing when you first get your sr? I was thinking something like this: Please add if I forgot something.
-Water Pump
-Oil Pan
-Complete Gasket kit (I will be replacing headgasket, so anything I should replace while i'm in there?)
-All new Hoses
-Belts
-Timing Chain Set
-Clutch and resurface flywheel
-Thermostat (Still cant decide between an oem or a nismo. Pros and cons to both)
-small stuff like spark plugs, oil filter
