NISMOlvr »
https://forums.nicoclub.com/nismolvr-u10357.html
Mon Apr 12, 2010 1:58 pm
keep it simple......If your car is in limp mode ,you engine will not rev past 2500rpms.So your problem is MAF related..As for engine harness ground wires,Yes they are very important.First check your MAF voltage and ground with DVOM ,If no voltage then check for continuity.IF voltage and no ground fix ground ,Dugh.There is allot of info here,Get a FSM pdf file search.1.Recheck your wiring to Maf and grounds,to engine and firewall.If thats OK then2.Find your self a sr20det ECU pin out.3.disconnect ECU harness @ ECU.4.find the 3 corresponding pins for the MAF at harness connector, and test for continuity to MAF connector PLUG,(3 wires,power to MAF,MAF ground ,MAF signal out.)
good luck ,keep it simple...
