The only plugs that are the same is the alternator and the little single female connector that goes to the starter. I just did a swap and I can tell you the transmission plugs and the plugs coming from the fuse box are definitely different.You are gonna need to splice the plugs from your KA to your SR harness. There are probably 10 trillion write ups so just search around and I'm sure you'll find something detailed enough to walk you through it. Good luck with everything! Matter of fact....... this is a nice start http://www.frsport.com/SR20DET....htmlaznrib wrote:u can use your ka lower harness in place of the sr lower harness. The plugs are the same.
did you just solder the wire from your SR reverse into the KA one?aznrib wrote:hm thats weird. Mine worked fine. I only had to modify the wires for my reverse switch.
