SR20det Limiter
MarketGarden
Hey guys, Im considering a s13 turbo swap and i have one question. Where can i get something to turn off the limiter so i can go above 115. And Are there any guge faces anywhere that can read up to normal sports car speeds like of 160mph? Thanks for your help.:ylsuper
Silvia007
Car: 93 Nissan 240SX SE Fastback
for the limiter, there are Mines and Tasami ecus on ebay right now for the SR20DET that has no speed/boost limit. A buddy of mine got a Mines from ebay and it works quite well, we maxed out in 5th gear... or should I say we approached the redline in 5th gear. Half our plastic skidplates rip out from under us and later we had to go back and pick them up coz getting them from the junkyard was almost impossible.
MarketGarden
so u have to buy a ecu just to turn off the speed cut? I know greddy and HKS sells some for other cars but its not on thier site. Are u sure no company makes a speed cut defender for the SR20det.
karter74
are you sure u even need one? thats all part of the ECU and since we know the ka has a limiter, u sure the sr has one to?
Silvia007
I know what you mean, I just saw a device like that on ebay but not sure if it'll work on all nissans. the thing is we didn't try and see if the stock sr ecu had a speed limit.
MarketGarden
yea, maybe the sr20det ecu doesnt have that lame limiter. and i found a good speedo at http://www.lsauto.com , I jut cant see how al those guys in japan can stand only going 115mph and not making a solution. But maybe it dosnt have one? I dunno?
240_Keyy
Car: '90 240 Fastback
SR is also limited...
