Sorry for the late response. Sounds like its not too hard of a task but I don't know if I trust myself doing anything internal. Ive never messed with timing or had to set the engine to tdc. Been trying to get a hold of the only mechanic I know of or dealt with here but am unsuccessful. I was hoping I could ask him about bleeding them for me and adding rocker arm stoppers. If he does say I should replace them I'd definitely be interested in buying your oems from you.
Another question
I've read that a lot of people remove the top timing chain guide. Last time I had the valve cover off I thought of doing it but wasn't positive I should. It sounds like the chain is rubbing it at certain rpms. I was going to get a new tensioner also. The motor has bc rods, je pistons, apexi head gasket, bc valve springs/retainers and bc cams. Thanks again. You guys are really helpful. Sorry for the newb questions.
