C4a0s »
https://forums.nicoclub.com/c4a0s-u41869.html
Sun Jun 11, 2006 6:30 am
Hi all,
Am new here. Got a problem which i hope someone can help
I drive a 1989 240SX with a S13 SR20DET BlacktopSome items i have...Motec M800 ECU with MAP sensorOgura Super Single ClutchBlitz ID boost controllerGreddy turbo timer
The problem:Recently, my engine keeps stalling. Whenever I clutch in, the engine dies. Some times on cold and warm starts, engine dies immediately after starting. Even more recently, at a huge jam, my engine died a few times and at each crank, turbo timer showed a decreasing voltage until it hit 9V where the car was totally dead. Friend had to jump start for me.
Next day, battery was full charged and car started as per normal.
Some friends and I feel that its the idle valve thats dirty and I'm getting it cleaned tomorrow but is that the only problem?
Why does the voltage drops so drastically with each crank? Could the battery/alternator be screwed cos the next day, voltage was normal?
Many thanks in advance bros. Would appreciate it if anyone has a clue to whats wrong...
later,C4a0s
