sr20det keep stalling!!!
Antony
I just did a swap, engine stays(about 2-3 secs) on but when i let off the gas it stalls.. could it be the vac hose not right? can anyone help me out
180fan
Car: 89 fastback
it could be a vac leak, but it should idle a bit high first for that. So wait, you give it a little throttle and then when you let off, it dies? if that's the case start poking around with a can of brake cleaner, unless you've forgotten to cap some ports.
