Sr20det jwt ecu, 50lb injectors, Z32 mafs anyone ever use these items?
mikesloud
Car: turbos and SPL world champ
I have that set up and want to know if anyone else has used it , and if anyone has a super afc2 to fine tune on wideband , what in and out setup numbers are used for 50lb injectors , jwt ecu , Z32 mafs please help with any information . thanks
robbbby
2in 6out
Lean your fuel out probably anywhere between -30 to -35 all the way across
Edit: Just reread that you have a safc 2, not sure if the in and out are different for those but 2/6 is for the original safc.
mikesloud
Nut i need numbers for the tuned ecu , I should be able to get start at zero, I am just needing numbers for remapped ecu jwt 50lb z32 mafs. Is it 2 in 2out or 5 in 5 out ?
Gladius
Well if your ecu is reprogrammed for the z32 maf, then the setting on the safc would be 2in/2out. If its not then its 2in/(whatever # the stock sr maf is) out.
mikesloud
Will that work on jim wolf ecu, Z32 mafs, 50lb injectors? 2 in 2 out?
