SR20DET into 04 Sentra
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
zodius
hello everybody this is my first time here so hello. the question i have is a two part one. the first is have a 04 sentra spec v and i was wanting to put the sr20det into it but not sure it will fit. I found the motor cheap with an awd trans. but not sure what type s13 14 or 15 i have done several searches i think it is a silvertop is that the same as one of the other models.n
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Yes, you can put a SR20DET into a Spec V. It is the same chassis as the 2000-2001 Sentra SE that came with an SR20DE. You don't need a sr20 from a s13/s14 or s15, those are RWD motors. You need either a Blue Bird, Avenir or GTiR motor. The AWD transmission is useless, you will have to source a transmission from the sentra I mention or a p11(g20T) transmission. Both of those will be pricey though, but are the strongest. You can also use a transmission from a 91-94 sentra se-r or nx2000, but beware of 5th gear pop out. The next affordable transmission I recommend is one from a 94-96 g20T, the gearing longer and works well with turbo engines. You would need a different ECU, wiring harness, motor mounts, cross member and axles as well.
zodius
good i thought i bought a new paper weight thank you. how does it work for upgrade parts most places spec the s13 14 15 do i need to look for the Avenir type engine or internally are they all the same like cam's for example.
nametakennow
Car: '06 MINI Cooper S
Look for stuff designed for a FWD engine. Unless it says "all" it won't fit "all."
got boost
Car: Spec V
So can you guys point me in the right directions for the sr20det motor mount kit into the spec v? this is my first nissan, have a turbo honda. So any help would be great, hit me back asap, thanks
nametakennow
I'd try to get in touch with a member by the username Trav4011, though he may have disappeared. He's done SR swaps into Specs including a very cool SR/QR hybrid.
Personally though, I wouldn't swap an SR into a Spec. The QR25DE has (generally) proven to be more resilient in modified form than stock.
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
got boost wrote:So can you guys point me in the right directions for the sr20det motor mount kit into the spec v? this is my first nissan, have a turbo honda. So any help would be great, hit me back asap, thanks
Motor mounts should be the same as the ones in the 2000-2001 Sentra with the SR20DE. I'd just get these from the dealer, unless you want to go aftermarket.
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
