IvoryJ30t wrote:heres what you want to have replaced-
good list, but dont forget the SR uses rocker arms!
updated list from the top down:
cam gears, timing chain, timing chain tensioner, timing chain guides, cams, rocker arms, rocker pivots, valve springs, retainers, shims, valve guides, valves, head gasket, pistons, rings [upper, lower, and oil], wrist pins, connecting rods, rod and crank bearings, crankshaft, oil pump, pump pickup, strainer, oil pan, water pump, flywheel, clutch, motor mounts, all necessecary gasgets and new hardware.
