compactfean wrote:I would start calling some companies that do porting work with a flow bench for that kind of info. I doubt the Isis Mani was flow tested. But the greddy has and shows HP gain above 6500 rpm's. What they don't tell you is that the stock Mani gives up to as much as 20whp more than greddy in the mid range. If I where to do it again I'd get my stock im extrude honed, ported, and bigger throttle body with flange to fit, and tig welded on in place of old flange. I will tell you that I bought a Freddy Mani and when I had my head ported they also flow tested my intake and exhaust Mani and they both didn't flow evenly and needed work.
Thats what i was thinking, i have seen the flow charts greddy give with there intakes and they are possitive after 6500 but is it worth the money when you can get that out of the stock mani. The bling factor of course but that does not bother me. I will do all my other mods and tune and see if i even want to upgrade the mani.
