sr20det injectors
Turb0wned
does anyone know any injectors that will fit a sr20det that will also upgrade?what i mean by this is what car can i take injectors off of and swap into mine that are bigger than my stock 370's
B.L
RX7's and some subaru's also use side feeds that are bigger then 370cc.
Turb0wned
all rx7's?
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
You could can get sard 550's on ebay for like 400.
Turb0wned
i know that but im tight on money and i would be able to get rx-7 injectors alot cheaper
do all rx-7 injectors fit? and are they all 550's
B.L
Primary inj are 550 and secondary are 850 iirc.
Turb0wned
huh it was a simple questiondo they fit or not....
Tartan
Car: 89 240sx
They fit. You might have to do some modifications though. I think the rx7 injectors are a little bigger but can be easily made to fit.
SR20DETPoweredS14
Car: 1999.5 Audi A4 1.8T
I say you buy aftermarket 440cc injectors because you wont want to get injectors that are too big or you may have to buy the Apex-i SAF to control the larger injectors from spraying too much but either way i dont think if you buy injectors that are no bigger than 550cc you wont have any problems of that sort
