SR20det injectors
jetroy240
Car: S13, AE86
Can oem S13 SR20det ecu can handle low impedance injectors? I understand these 370cc injectors are high impedance (approx. 11 ohms) .I was just wondering, I have a 550cc injector from a 2003 EVO 8 w/c has approx 2.3 ohms, top feed w/c fits exactly on my top feed fuel rail, just need to get the right connector. Will it need injector resistor probably?
Yep, found the thread related to this posted by Edub1 dated 7/13/2007, just confirmed my research that these S13 SR20det stock ecu has saturated injector driver circuits. To make everything simple, I just have to use high impedance injectors if I'm gonna go for high capacity injectors.Thanks Edub1, that's a very good thread.
Modified by jetroy240 at 10:30 PM 8/3/2008
