574-240sx wrote:Why not look into a G20/Sentra, the 99+ G20T are badass. They are some nice cars. Believe me you won't look back on honda. But more power to you if you get the swap done, I wish you the best of luck.
Ah, the old "Civic of the Sun", based on the 5th gen Civic.
Only part I disagree with there is that the G20 is a freaking tank at nearly 3000lbs. I personally would take an Integra over a G20 anyday, but that's not why we are here.
If you are willing to spend that sort of money I would highly recommend using a B18C engine from an Integra Type R. The engines are even more expensive than an SR20DET though (maybe that's why he is looking at an SR20DET). A simpler swap might be a nice and straight forward B16A. The 1994+ Civic Del Sols came with them, and it would be very straight forward. Another slightly more exotic is a B20B from a Honda CR-V, and attach a B18 head to it. Check the Honda forums for information on that.
I would also recommend against the H22. They make tons of power, but they are rather heavy. A B series would keep things nice and light. Also, I would follow up on aaronsnocker1's lead. Hasport has motor mount kits to put the H22 in the Del Sol. Also, they have a mount kit to install the K series in a 1992 to 1995 Honda Civic. Now the Del Sol is based on the 92-95 5th generation. I suspect that it might be possible to use those mounts on a Del Sol, but you would want to call Hasport first.
PS: Almost forgot: If you want to convert to RWD, my recommendation is to find a RWD car. I understand that drivetrain conversions are the hardest to do.
