BuudWeizErr »
https://forums.nicoclub.com/buudweizerr-u1639.html
Mon Sep 30, 2002 4:39 pm
If you are going to get an S13, you shouldn't spend more than like $2K. I got mine for $1500, it has some nice rims on there, and it had a blown head gasket. Perfect candidate for an SR swap. Probably could have gotten it for $1200, but I wanted the rims.
Next, if you intend to have a nice, quick little car, but never mod or upgrade it, then an S14/S15 SR20 swap would be a smart idea, because those engines have more power out of the box, due to bigger turbos, and VTC. If you intend to upgrade it, like most people do, then the S13 SR20 engine is a better choice; reasons being the intake design is different, and also, if you upgrade cams on an S14, then you lose the VTC, in essence knocking you down to S13 status. If I remember correctly, the turbos are a little different, but that still wouldn't justify the price difference (at least not for me).
I personally haven't researched the price for an installation for an S14 into an S13 shell, but for an S13 -> S13 conversion, I've seen anywhere from $1500-$2500, I'd expect at least $2000.
Another thing you might want to consider is that getting the AC to work on S14 swaps haven't been very successful. Apparently the wiring is a real PITA to do, if it's even been done at all yet.
If you want my opinion.....Take your $15000, find the cheapest S13 you can find, have the S13 engine installed, that'll take away 5-6K. Then spend the remainder on making it a 1320 dragger, or an autox champ.
Your decision though.
