ballinnmiami240sx »
https://forums.nicoclub.com/ballinnmiami240sx-u33761.html
Sat Apr 11, 2009 3:25 pm
Car setup:s14 srz32 mafs15 injectorss15 t28s14 1996 zenki odbll
I am trying to help a friend get his SR running after a few have tried and failed. So far I have tested power to the ignitor and its getting no power. Grounds check out to good .02 ohms. I have tested pin 1, pin 2, pin 11, and pin 12 on the ecu and they show 0v when ignition switched. I have yet to fully test the ignition relay, but will do that tomorrow. all fuses and ground check out fine. ECU is receiveing voltage and the grounds have been properly tested.
I have tested these pins to ground checking for power and nothing comes up.....0 volts. As I understand it, according to the schematic I should receive 12volts when switched. please correct me if I have misunderstood something.
So if I test from the ecu pins 1,2,11,12 to ignitor I should see voltage? Correct
Ground to ignitor also checks out good.......
thanks for looking,Danny
