180fan »
https://forums.nicoclub.com/180fan-u3602.html
Mon Sep 26, 2005 10:28 pm
Depends on which sensors. If it's like a Z32 MAFS, might want to check ebay but be smart about it.
Otherwise if you want new parts, you can try Dantech of Midway Autoparts. I basically went through him to replace all the nuts and bolts on my car and several others along with buying a bunch of oem parts to replace worn parts on 2 nissans that needed suspension parts, sensors, etc. He's a great dealer to work with.
But if it's small stuff, you're probably better off buying locally since you won't need to go through shipping. Like your coolant temp sensor. I bought that from Kragens for like 12 bucks? You can check the SR parts thread for part numbers that you may need for replacement parts.
Remember though, certain parts are Japan only. Like the IACV is Japan only but you can find them cheap enough. I sold my spare for like 10 bucks a while ago. I'm sure there are other deals like that floating around too.
Good luck!
