SR20DET hydraulic lifter Shim querstion
Mitchum
Car: 2000 Dodge Dakota
1995 240SX
hey im just now assembling my head, its the complete BC head package from enjuku racing. Im just confused at how to properly measure and Shim the hydraulic lifters. I have the factory FSM but cant seem to get a grasp on proper procedure. Any help explaining how to properly measure the clearance to be shimmed would be greatly appreciated, thank you so much!
Hijacker
Car: '92 240sx Convertible
'94 F-150
I mention ways to do it in my SR rebuild guide.
But cliff notes for you:
You need a dial gauge. Nissan uses a specific mount to position it in the HLA hole. There are some aftermarket solutions for this. Someone was renting one on NICO a while ago I think.
Place the notched guide in place and measure the height of the notched surface.
Measure the height of the valve stem of the valve that needs a shim (the notched guide's pair).
Subtract the two numbers to get your shim thickness.
The shim is to help keep the rocker arm perfectly level under operation.
I have a less accurate way of shimming listed in my guide. I recommend the FSM procedure if you can swing it, but the method I've listed will work. Just don't be bouncing off the rev limiter.
