Sr20det how to wire from ecu to get running, eg: ignition fuel pump
Adrty1
Hijacker
Car: '92 240sx Convertible
'94 F-150
Hi! Welcome to NICO! There are plenty of wiring guides out there, so you need to be more specific. Perhaps if you state what your problem is, we can get you some help. Is your fuel pump not turning on? Also, knowing what generation of motor and car you have is information that will aid in helping you with your problem.
I've also moved this thread to the RWD SR forum, but have left a shadow link in the general chat forum to help keep generating traffic towards it.
oLemurs
Car: 2005 Mazda 6, 1978 Buick regal, 1993 240sx
if your fuel pump wont kick on you can bypass the ECU by putting a wire from the top right terminal to bottom left on the EGI pump, by top right and top left i mean by standing at the right fender looking torwards the engine bay, i dont really know the numbers but im sure someone will. if it turns on then you know its a problem with your ecu or wiring to the ECU
