sr20det high idle
Babyj609
Car: 1995 Nissan 240sx SR20DET Blacktop
My car idles around 1500 rpm's. I'm still new to this car, and it use to idle at 1100, which i thought was ok. But reading on it more i found out that was even high. What can i do to bring the rpm's down safely?
Hijacker
Car: '92 240sx Convertible
'94 F-150
Adjust the idle air control valve. There's a screw on the valve that's visible between the 2nd and 3rd runners of the intake manifold
s13blake
Car: 240sx hatch rhd
do what he said adjust your idle air
and check for vaccum (sp) leaks
maj Andres
Car: Zenki, '95 Model, w/ S14SR20DET
well.. my car idles up to 2k rpm when it's cold and then drops down to 1.5k after about a min and then down to 1k after another min. Is this normal. (S14 SR20DET)
redclaw05
Car: 1993 s13 caged vert
yes thats perfectly normal. as long as when its warm its around 700-1k you are fine.
you can check the IACV, throttle cable, or check if your car is running too lean at idle.
maj Andres
After trying to wire up a relay so I can arm the car while it is still running I managed to start the car in the ON position. Rewired everything back up and it started at 1k rpm's from the get go. I didn't have to wait 2 min for the rpm's to drop down. Is this good? Link to the relay thing i'm trying to do: zer...18466
